Ping... - Road Glide Forums
post #1 of 12 (permalink) Old 06-27-2014, 02:51 PM Thread Starter
OneSlickGlide's Avatar
Ping...
I have a '13 RGU with a stage 1 AC, PC5 & an auto tuner running. Everything seems to be running ok however once I ride for a while and the bike gets nice and hot, rolling along sound 25-3k RPMs and crack on the throttle and I get what sounds like a loud, Metallic tap or ping from the engine.
This only does it when the bike is hot. I only notice it ever since I've installed the exhaust, PC, AC & AT.
Any ideas what this is or how to fix it. The AT seems to be working correctly because it does show AF ratio changes in the PC software when hooked up to my laptop.
Any help would be appreciated to get rid of this. I do not believe this is normal but I could be wrong.
Thanks
OneSlickGlide is offline
post #2 of 12 (permalink) Old 06-27-2014, 02:54 PM
ChivoChavez321's Avatar
Mine does the same. Sounds like valve train clatter coming out of the air cleaner. HD says its normal, especially since I have a woods 777 cam. Over 3000 no noise.
2013 Big Blue Pearl Road Glide Ultra. Monster Ovals, Jackpot Ceramic Headers, Fuel Moto Power Vision and Billet Air Cleaner, Oil Temp guage, saddle bag bumpers, 11.5" rear progressives 444, monotubes -1, Woods TW-777 cam 107 FM kit with Level B Heads, polished throttle body. 123 Torque/113HP. "Lord, help me to be half the man my dog thinks I am"
ChivoChavez321 is offline
post #3 of 12 (permalink) Old 06-27-2014, 02:56 PM
PGR
PGR's Avatar
If it is pinging......Figure out when it happens as far as RPM and speed, then manually retard the spark just a little in that range.
I had a little bit of ping, so I pulled about 1/2 degree of spark out in the map at the spot where it was doing it, and the ping is gone.
If it's mechanical noise, and it really bothers you.... you will have to throw money at it.
Ron..........................
PGR is offline
post #4 of 12 (permalink) Old 06-27-2014, 03:23 PM
mitchdm's Avatar
Go into the PCV and put -2 on the ignition table in the pinging range assuming that the ignition table is all zeros ~ then send the update to the pcv ~ this will do it ~ you are retarding the timing manually. You can go more but don't want to use more than necessary. I have not pinging and am actually adding timing. As long as there is no ping (detonation) all is well. If I get a ping I will retard -2 degress till all is well.
mitchdm is offline
post #5 of 12 (permalink) Old 06-27-2014, 05:12 PM Thread Starter
Ping...
Alright. I'll give it a try. It ONLY seems to happen whenever the engine is hot also. Never within the first 30 mins of riding. Only when it's hot and from what I can tell, only in the 25-3k range.
post #6 of 12 (permalink) Old 06-27-2014, 05:33 PM
HellInABucket's Avatar
Its definitely valve train clatter.
I had the same issue with my '13 FLTRU, it was driving me NUTS.
I was certain that when Jamie pulled my jugs for my 107 build he was going to show me pistons riddled with pinging damage.
Nope, they looked very good.
I had them rebuild my heads (not ported), so new (better) valve springs, seals, etc.
Guess what: no more clatter! Just a strong, happy, purring motor.....
HellInABucket is online now
post #7 of 12 (permalink) Old 06-27-2014, 06:17 PM Thread Starter
Well that's good to know. I'm always afraid my engine is gonna go kaput sometime.
post #8 of 12 (permalink) Old 06-27-2014, 11:47 PM
Yup,I was considering the 107. My clatter drives me nuts. Was thinking about going back to the stock cam. While driving the twisties in S.Dakota Hill City,Sturgis,Deadwood, etc., the clatter was relentless. The most clatter is 2700 to 2800 RPM's. I guess if it causes no damage I might leave it. Otherwise thinking about going back to stock cam/aircleaner. Or just the air cleaner to muffle the sound. Of course a 107 with no clatter sure would be cool!
post #9 of 12 (permalink) Old 06-28-2014, 08:25 AM
Mine does this too. Especially if your pushing hard in the hills or on the interstate. I had assumed timing ping, but had run the TTS recorder several times with the ping occurring and no timing is being pulled. So, I figured it might be a tad lean in that area. Haven't gotten to messing with that yet though. May not after reading this thread, as I have Andrews 54's. Was going to do heads, but held off. Looks like a good reason to get it done now. Good stuff guys!
Mike
2013 RGU
speedjunkie is offline
post #10 of 12 (permalink) Old 06-28-2014, 10:39 AM
Most of the time the ping is the timing not the AFR. T-Max has a timing vs engine temp feature where you can set the module to retard the timing a couple of degrees when the engine temp hit your selected temp. I am not sure if the PV has this feature.
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 02:52 PM
stage 1 to stop engine ping? StriderJim Road Glide Specific Discussions 18 01-30-2012 06:34 PM
ping... Ping... PING philmartin *General Road Glide Discussions/Pictures 20 07-25-2011 10:10 PM
Ping and Stutter whispanic Troubleshooting for Road Glides 10 05-23-2011 12:21 PM
Heard a "PING!" when riding today okcdoughboy *General Road Glide Discussions/Pictures 26 05-06-2011 12:03 PM
