motor swap - Road Glide Forums
post #1 of 11 (permalink) Old 07-03-2014, 07:55 AM Thread Starter
motor swap
The motor in my 2004 comepletly imploded. Looking for new or like new pull out motor to swap in. How much trouble will it be to use a 96 or a 103?
Hookspurs is offline
post #2 of 11 (permalink) Old 07-03-2014, 09:51 AM
JacktheBagger's Avatar
the engine and trans on the 96 and 103 are bolted together , different frames , best to either rebuild yours , or put a S&S crate motor in there
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 11 (permalink) Old 07-03-2014, 10:09 AM
tdkkart's Avatar
Check into Harley's rebuild/remanufacture program, usually not a bad price and you get really close to a new motor with a good warranty9if installed by a dealer).
tdkkart is offline
post #4 of 11 (permalink) Old 07-03-2014, 11:04 AM
A friend of mine 2000 RG engine blew up about 3 weeks ago and when he was at the HD dealer discussing repair options the service manager was informed by the MOCO that the engine reman program was being phased out and there was only 10 days left.
So the MOCOs reman program is not an option anymore but you may want to verify this to make sure.
Another problem with the reman program was you had to have the HD do the R&R on the bike and the engine had to be shipped from a HD dealer. So you are stuck with the labor cost and shipping cost.
There are some reasonably used 88 inch engines on ebay.
post #5 of 11 (permalink) Old 07-03-2014, 11:55 AM
Iam with JTB, time to start exploring local builders on their abilities, likly S&S would recommend in your area or would provide detailed installs you should be able to do yourself, then have it fine-tuned. Go with Hillside or Dragos-plan A
reds4 is offline
post #6 of 11 (permalink) Old 07-03-2014, 02:29 PM
If the crank and crankcase is still good than rebuilding the top end is a easy DIY and it doesn't cost a lot and you don't need to pull the engine to do it.
If the crank is bad than pull the engine and tear the top end down and send the bottom end to a machine shop for repairs. New jugs and pistons and a set of used heads won't cost you a lot. If you are lucky your jugs can be punch to a 95 inch or .010 over which ever works for you and heads can be reconditioned. I had my stock heads reconditioned at the local auto machine shop for $50 each, I had to provide the valve seals. The auto machine shop will bore the jugs too.
post #7 of 11 (permalink) Old 07-03-2014, 03:31 PM
Here is an 03 for pretty reasonable money and a 6 month parts warranty.
http://www.ebay.com/itm/2003-03-HARL...9967a7&vxp=mtr
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is online now
post #8 of 11 (permalink) Old 07-03-2014, 04:07 PM
I don't thinketh that motor for the FX will werk in the RG , may be wrong
JtB
2011 Ultra
post #9 of 11 (permalink) Old 07-03-2014, 04:26 PM
sfcusaret2004's Avatar
if your around the southern Alabama area, Accurate engineering in Dothan does an awesome job with engines. Check 'em out.
sfcusaret2004 is offline
post #10 of 11 (permalink) Old 07-04-2014, 08:20 AM
JtB
You are correct Jack. That is a "B" engine and the touring models take the "A" engine.
motor swap Deadstroke Engine Related 10 04-21-2017 11:29 AM
Just a little motor swap..... Gunslinger Road Glide Builds-Document your builds HERE --NEW 31 07-14-2015 02:33 PM
05 Road Glide motor swap V-style Road Glide Builds-Document your builds HERE --NEW 4 09-15-2014 09:41 PM
Rear Shock Swap pte359 Aftermarket Accessories 19 07-23-2010 10:13 PM
Engine swap. Roadie *General Road Glide Discussions/Pictures 21 04-28-2010 08:20 PM
