Transmission trouble? - Road Glide Forums
post #1 of 8 (permalink) Old 07-03-2014, 12:54 PM Thread Starter
Sorry if this is in the wrong location, I didn't see a transmission section.
So this is my first Harley. It's a 98 RG, with 30-40k miles to the best of my knowledge. I just had it at my independent mechanic for a once over, state inspection, etc. He said the tranny fluid was very dirty and should be changed again very soon. I'm having a heck of a time getting it into neutral. I've also had a few "miss-shifts", where it acts like I'm between gears and in neutral (but not between 1st and 2nd). Also I can hear a decently loud wining when I'm in 4th gear only. Are these all signs that my tranny is about to shit the bed? How much is a new tranny?
PAhumbug is offline
post #2 of 8 (permalink) Old 07-03-2014, 01:19 PM
I would change all the fluids, oil, primary, tranny to start with, harleys are notoriously hard to get into neutral sometimes especially if the bike is not moving.
2013 RGU, black of course....
y2kflhr is offline
post #3 of 8 (permalink) Old 07-03-2014, 01:21 PM
PGR
PGR's Avatar
I have never seen trans oil actually look dirty. If it does, then change it. Change it with a good gear oil like RedLine or BelRay gear saver. Just doing that might make things smoother.
Ron..........................
PGR is offline
post #4 of 8 (permalink) Old 07-03-2014, 02:33 PM
Make sure your clutch is adjusted properly.
Big_gary is online now
post #5 of 8 (permalink) Old 07-03-2014, 02:34 PM
^^^What PGR said^^^
I use Mobil 1 75w140 or Valvoline 75w140 full synthetic gear lube in the tranny and you get get either one at Autozone. The other products mention will work good too.
post #6 of 8 (permalink) Old 07-03-2014, 02:47 PM
Clean&Sober's Avatar
+1 on checking your clutch
2013 FLTRX Custom, 16" back Hill Country apes. Full header Python Momba pipes with a stage1 kit. Boom Speakers. 11" gun smoke Windvest windshield
Clean&Sober is offline
post #7 of 8 (permalink) Old 07-03-2014, 03:29 PM Thread Starter
Thanks guys I'll look into the clutch adjustment. Just to be clear, my mechanic DID change the tranny oil (and primary and engine). He said it was very dirty so I should change it again soon to get more of the dirt out.
PAhumbug is offline
post #8 of 8 (permalink) Old 07-03-2014, 04:02 PM
It would have been nice to send a sample out for analysis. Lots of metals? Time for a tear down.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
Transmission oil capacity aviaator Road Glide Specific Discussions 8 07-21-2011 07:56 PM
Close call- check your transmission cover bolts! Govdog76 Troubleshooting for Road Glides 4 07-17-2011 09:06 PM
Transmission problem? staush Troubleshooting for Road Glides 6 05-16-2011 09:31 AM
DIY-Oil/Transmission Fluid change videos..... CRAIG2 Videos 2 05-13-2011 12:11 PM
Transmission problem vontoughguy Troubleshooting for Road Glides 4 08-19-2010 05:30 PM
