Cam Install possible issue - Road Glide Forums
post #1 of 13 (permalink) Old 07-03-2014, 03:31 PM Thread Starter
I just installed drago's 565 cams in my bike. After checking the crank and cam sprocket alignment. When I put the chain back on I didnt pay attention to the dots and the timing was off and the bike wouldnt start. I started over and got it right and the bike fired right up. I set the the pushrods at 4 turn per S&S's instructions. And installed new lifters as well. Only has a little miss/stumble at about 2500-3k with the generic map I have, other than that seems alright.
What are the chances I hurt the valves while trying to start it with the timing off? Would it run really bad if the valve was bent?
I am going start by getting a compression tester seeing what the reading is. I want to make sure all is good before sending for Dyno tuning.
Makes me feel like a idiot that I goofed it up. But SH*T happens I guess.
[B]PV-Big Sucker-Rush Racing H-pipe-Big Louie's-Drago's 565 cams
Nightrain04 is offline
post #2 of 13 (permalink) Old 07-03-2014, 03:42 PM
pat123's Avatar
It's the tune. If you bent a valve it would run bad from idle to redline. Not just at 2500-3k.
I a compression test to make sure.
pat123 is offline
post #3 of 13 (permalink) Old 07-03-2014, 04:17 PM Thread Starter
That is my next step.
post #4 of 13 (permalink) Old 07-06-2014, 09:14 AM
MyGlide's Avatar
Odds are you're alright and its just the tune. Generic maps are just a starting point to get you in the ballpark.
2018 KTM Super Duke R
MyGlide is offline
post #5 of 13 (permalink) Old 07-06-2014, 10:03 AM Thread Starter
I got a tester and will check later on today. I am also wanting on my Rush racing h-pipe to get here before dyno tuning.
post #6 of 13 (permalink) Old 07-06-2014, 11:30 AM
faststan's Avatar
Did you check the location of the O2 sensors, gray/front black/rear. You must have removed the exhaust to put in cams.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #7 of 13 (permalink) Old 07-06-2014, 11:41 AM Thread Starter
I only took off the rear pipe as I have true duals. I only unplugged the rear sensor(grey).
My guess is the tune as well. As it runs pretty decent. What I have read it would run pretty horrible with bent valves. Maybe I dodged a bullet with my error on reassembly.
I will probably have valley racing in IL do the dyno tune on it. They seem to have a great rep on the forums.
post #8 of 13 (permalink) Old 07-06-2014, 11:48 AM
kouack's Avatar
What are you using for tune, you are not saying if you are using a tts,pc,pv etc... I guess only the stock ecm?
kouack is offline
post #9 of 13 (permalink) Old 07-06-2014, 11:49 AM Thread Starter
A power vision. Drago provided a base map. I feel I am best off to just have it tuned.
post #10 of 13 (permalink) Old 07-06-2014, 12:26 PM
pat123's Avatar
Frank gave me a tune for my 580 cams and it sucked bad. I pro auto tuned it 15 times and could never get it below 18%. It wanted to cap or scale the tune every session. I ended up using a fuel moto tune for woods 555 cams and got it spot on in 4 auto tune sessions. It runs great now.
If you want I can send you this map. Might be closer.
pat123 is offline
Possible clutch issue. Chromedclassic Engine Related 1 03-20-2016 07:24 PM
help. cam swap issue milkman48 Engine Related 7 04-01-2015 07:11 AM
Is there still a cam tensioner issue mr_reality Engine Related 24 04-11-2014 06:23 AM
Electrical possible sensor issue...??? Johnzz1420 *General Road Glide Discussions/Pictures 5 08-05-2013 05:31 PM
Apparently, this isn't my week. Possible clutch issue RGCBandit Troubleshooting for Road Glides 3 10-15-2012 09:53 AM
