no power - Road Glide Forums
post #1 of 17 (permalink) Old 07-05-2014, 11:18 PM Thread Starter
no power
All right guys 103 six speed with no power. Rev the bike and imediatly after letting throttle go it goes to idle like its being held up. Checked oil amount in motor via allen plug in bottom of the motor the correct amount came out. Took primary cover off and chain was way tight!!! got it to loosen seemed to actually make a difference on the lift rode bike and was back to same problem motor is being held back.. Ordered adjustable tennsioner installed and got a very loud noise from primary. Took cover off and all looks good took clutch and every thing apart and it looks and feels all good bearing seems intack and noise free. Tranny shaft seems a little stiff to turn...Any thoughts on this??? pls help
midwaywfo is offline
post #2 of 17 (permalink) Old 07-06-2014, 06:49 AM
JacktheBagger's Avatar
are you throwing codes ??
WAG is something in the TBW
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 17 (permalink) Old 07-06-2014, 08:23 AM
FDR's RGC's Avatar
You're the mechanic. It says so in your bio. is it going into limp mode?
FDR's RGC is offline
post #4 of 17 (permalink) Old 07-06-2014, 10:29 AM Thread Starter
no codes no limp mode... and yes i am the mechanic true but even i need some advice!!! Last time this happened it was a plugged oil passage but this time it is not..Wondering with the primary chain so tight it broke the tranny bearing..i know theres alot smarter guys out there thats why i ask questions
post #5 of 17 (permalink) Old 07-06-2014, 12:16 PM
FDR's RGC's Avatar
The year helps. Be guessing at 2011 and up. FBW connections on 08's and 09's. Strange no codes. You could drain trans and see if metal shavings are present. Busting chops as far as your bio. That's why the
post #6 of 17 (permalink) Old 07-06-2014, 08:10 PM Thread Starter
i checked the tranny nothing and it runs fine except the no power thing lol if that makes any sense at all. i had an 03 that did this turned out the oil return passage was blocked from the engine case oil would load up and shoot out the breather..This one does not do that so its stumped me dont wanna just tear it apart and charge the shit outa the guy but if it were my motor i woulda already... its a tbw bike yes but its not that..ive heard that these auto adj. chain adjusters can wreak havoc but never experienced it myself...BUST BALLS buddy just trying to say im humble and need input from you guys!!! lol
post #7 of 17 (permalink) Old 07-06-2014, 08:11 PM Thread Starter
its a 10 btw
post #8 of 17 (permalink) Old 07-07-2014, 06:52 AM
Pull the crankcase drain plug, and measure the amount of oil in there.
4-6 oz. is normal, have seen 8 oz still OK.
Sounds like you have more than that..........
Scott
Hillsidecycle.com is offline
post #9 of 17 (permalink) Old 07-07-2014, 09:03 AM Thread Starter
hey hillside yea that was the first thing i did..customer said that he parked it and then a week later he started it and then he had no power.. im at a loss here
post #10 of 17 (permalink) Old 07-08-2014, 06:34 AM
I see that now in your original post.
The way your describing it, sure sounds like sumping.
Throttle plate fully opening?
Scott
15 FLTRX Vivid Black............No Security & No ABS maddmoe Road Glide Builds-Document your builds HERE --NEW 135 08-28-2016 01:30 AM
NO OIL and no idiot light?? motodrummer Troubleshooting for Road Glides 16 06-18-2015 10:48 PM
Passenger floorboard mounts. No spring, no ball. Mounts only.40.00 shipped neverdone Sold 1 05-13-2014 07:57 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 03:14 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 06:02 PM
