Shovelhead sumping - Road Glide Forums
post #1 of 11 (permalink) Old 07-08-2014, 11:12 AM Thread Starter
Shovelhead sumping
I know most you guys will have twin cams (so do I) but I have a shovel that if it sits for a while will push about a pint out the breather. I suspect the check valve in the pump, last time it was apart it got a new ball and spring and the builder lapped the seat.
Any way to improve this situation?
BTW only one of my shovels do this, the other is just fine (in fact I don't think it has ever been apart).
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #2 of 11 (permalink) Old 07-08-2014, 11:20 AM
Keep clean oil in it before storing helps. Also , I run Lucas oil additive in mine and it helps from drying out and causing the valve to stick open.
post #3 of 11 (permalink) Old 07-08-2014, 07:08 PM
FDR's RGC's Avatar
How did your builder (lap) the seat. Usually tap the check ball with a skinny drift punch, fish it out with a magnet. Replace with new ball. My stroked shovel was done that way and no problems.
FDR's RGC is offline
post #4 of 11 (permalink) Old 07-08-2014, 07:58 PM
hey fdr i have a 72 shovel and i lapped the ball in when i re re re built it and almost all shvels i run across have this issue in which i just smack it with a drift which usually cures it worst case youll have to pull the pump and lap it in
midwaywfo is offline
post #5 of 11 (permalink) Old 07-08-2014, 07:59 PM
whoops sorry fdr i thought this was your thread
post #6 of 11 (permalink) Old 07-08-2014, 09:47 PM Thread Starter
Thanks guys, anybody got a shot of the lapping tool for this? I got lathe and mill to recreate.
post #7 of 11 (permalink) Old 07-09-2014, 01:22 AM
waynemags's Avatar
all it takes is a little flaw on that ball or seat.
12 FLTRX, Bassani Road rage, Roland sand AC, Thundermax, 16" Apes, custom wheels, SE 255 cams,Barnett Scorpion clutch, progressive 944 rear, Progressive mono lower 1inch front, and soon to come Baker 7 speed, and 11" Madstad, HD Daymakers
waynemags is offline
post #8 of 11 (permalink) Old 07-09-2014, 09:26 PM
hogrider all it is is a ball welded to a rod thats it use the same ball youd use for the pump just by a couple.. theyre cheap
post #9 of 11 (permalink) Old 07-09-2014, 10:16 PM Thread Starter
OK thanks for that. I didn't know if the seat was spherical or just a cone shape.
I have some diamond lapping compound, I think I will cut a cast iron one to charge the diamond compound into the surface of the cast iron.
post #10 of 11 (permalink) Old 07-10-2014, 05:56 AM
That tool is easily made, but we purchased an actual cutter from S&S some years ago to attend to that seat.
Not for nothing, but even new Softail's drain into the cases, but it is thrown back to the bag upon start up.
Scott
Hillsidecycle.com is offline
sumping 2017 RGS Stage 1 2016CTRoadGlide Engine Related 19 07-02-2018 07:42 AM
Stage 3 & 4 upgrade oil sumping issue RG Mark Home Page News 5 05-22-2018 07:31 PM
Wet Sumping vgfxst05 Engine Related 11 06-22-2015 08:10 PM
Jumpin-Shovelhead Wood *General Road Glide Discussions/Pictures 7 01-24-2015 01:42 AM
Sumping issue Uncleford Engine Related 11 08-13-2014 06:37 AM
