SE 255 hard start fixed. - Road Glide Forums
post #1 of 3 (permalink) Old 07-11-2014, 05:23 PM Thread Starter
I installed manual compression releases in my 09 with 103 with SE 255 cams a few weeks ago what a difference. So much better now. If you're running 255's in a 103 without releases get them you will be much happier. Other than the machine work it can be done at home with manual a good set of hand tools and a couple torque wrenches. You will also need a couple torque wrench adapters for the rocker boxes and rocker arms. I purchased mine from McMaster-Carr industry supplie. For something like $35.
Reddobe1 is offline
post #2 of 3 (permalink) Old 07-12-2014, 09:52 PM
pacfan1967's Avatar
They do make a big difference.
Here's a little tidbit I learned yesterday that you may want to file.
My bike is a 103, with a SE pro racing stage 3 kit, 255 cams, manual releases, and head work. Over the last few months I would occasionally have hard starting issues and couldn't figure it out. The bike finally stranded me yesterday and I was pissed thought maybe it was a compensator issue as all the Harley techs told me that was the problem. Note - they didn't actually diagnose the problem just told me that's what I needed which I didn't believe.
So, after tinkering with it for 3 hours I finally figured out my fuel check valve is having issues. I unplugged it, plugged it right back in, and vroom she fired right up. Seems the fuel check valve can act almost like an d vapor lock.
So, since the manual releases would pop after a couple revolutions the bike would kick back and spit out the AC if it didn't start.
You can check it by simply unplugging your fuel line (being careful not to lose or damage the I ring),plug it back in, and see if she fires.
Ride safe, Gary
pacfan1967 is offline
post #3 of 3 (permalink) Old 07-14-2014, 10:29 PM
That is a good tip. Would it apply to a 2006 with SE stage 2? Is there a compression release for that vintage?
grambo is offline
How hard is too hard? tlottman *General Road Glide Discussions/Pictures 11 08-28-2015 07:42 AM
FS SE Pushrods(adj & fixed) akjeff Parts for Sale 3 01-01-2014 09:22 AM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
SE-255 Cams, SE Head Pipe, RCX Slipons ldireprophil Parts for Sale 11 06-17-2013 11:11 PM
Se 259e vs se 255's urika391 Engine Related 1 01-09-2013 08:21 PM
