Slappy compensator? What to look for? - Road Glide Forums
post #1 of 18 (permalink) Old 07-18-2014, 02:25 PM Thread Starter
hometoast's Avatar
Based on this thread (https://www.roadglide.org/showthread.php?t=159433), and others I get that there MAY be some loose spring or maybe the auto-tensioner isn't auto-tensioning?
The dealer gave me the "its normal" spiel. If I were to pull the primary cover this winter, what would I look for in terms of evidence of impending failure?
I don't get the 'shutdown clunk' people describe, but I have occasionally got the 'hard start' others have described, where it sound slike the whole thing binded up for a sec when turning it over.
2013 Candy Orange FLTRX
hometoast is offline
post #2 of 18 (permalink) Old 07-18-2014, 04:08 PM
FDR's RGC's Avatar
Do you get a grinding noise when trying to start sometimes? Metal shavings on the drain plug. You can adjust the tensioner by accelerating in 1st to 30 mph apply rear brake till it almost stalls without pulling in the clutch.
FDR's RGC is offline
post #3 of 18 (permalink) Old 07-18-2014, 09:36 PM
Dmize's Avatar
is this for real? Cant tell if your being sarcastic.
D
D.Mize
16 CVO RGU
Dmize is offline
post #4 of 18 (permalink) Old 07-18-2014, 09:58 PM
D
Yes, it ratchets it up > tighter
post #5 of 18 (permalink) Old 07-18-2014, 10:07 PM
Dmize's Avatar
ok thanks. Im a sucker so I needed to make sure
D.
D.Mize
16 CVO RGU
Dmize is offline
post #6 of 18 (permalink) Old 07-18-2014, 11:25 PM
Hullhorr's Avatar
There is no need to tighten the primary chain prematurely. The stock tensioner will ratchet tighter as necessary. If you intentionally create slack in the chain to tighten the tensioner you will put excess strain on the inner primary bearing and transmission main bearing.
That is the problem with the stock tensioner. It will tighten, but it won't loosen without disassembly.
2009 FLTR MOP
Hullhorr is offline
post #7 of 18 (permalink) Old 07-19-2014, 12:25 AM
waynemags's Avatar
don't accept the its normal Harley crap. get it in. it will destroy your clutch hub and eventually your crank. mines in right now at the dealer completely against my will for all the repairs. only because its under warranty and im tired of flipping the bill for their under engineered crap.
12 FLTRX, Bassani Road rage, Roland sand AC, Thundermax, 16" Apes, custom wheels, SE 255 cams,Barnett Scorpion clutch, progressive 944 rear, Progressive mono lower 1inch front, and soon to come Baker 7 speed, and 11" Madstad, HD Daymakers
waynemags is offline
post #8 of 18 (permalink) Old 07-19-2014, 07:42 AM
D.
To loosen, do the same in reverse.
+1 on what hullhorr said.
post #9 of 18 (permalink) Old 07-19-2014, 07:44 AM Thread Starter
hometoast's Avatar
No grinding noise when starting. Except that it seems like it'll bind and I have to turn it over again. I've read the how-to tighten the chain procedure, but had reservations that hullhorr mentioned.
There were metal shavings on the plug when I changed the oil at 5k, but only "a little amount". Maybe I'll make a trip down to the dealer where I got it (the local ones seem retarded).
@waynemags: Is that kind of abnormal wear visible with only pulling the cover off? I don't mind pulling the cover to know I have a problem, but disassembling anything else would likely have be causing more trouble than I started with.
post #10 of 18 (permalink) Old 07-19-2014, 10:17 AM
waynemags's Avatar
you will be able to see the wear on the ramps without tearing compensator apart. its pretty simple to get the comp apart and its not gonna cause any more problem than you already have. you can take the nut off with a breaker bar and reassemble without taking whole primary chain and everything out. just make sure to put a zip tie around the auto tensioner before you take the nut off. that way it stays under tension and you can put the comp sprocket back on and the chain with no issues. torque engine bolt to 140 ft lbs
New Compensator or Compensator eliminator mrmoto95 Engine Related 11 03-28-2018 08:10 PM
What does a failing compensator look like thedrill Engine Related 19 01-27-2014 11:00 PM
Compensator sprocket tourglide Troubleshooting for Road Glides 13 01-18-2011 02:47 PM
Belt Drive Limited Compensator mrbill Troubleshooting for Road Glides 0 12-19-2010 08:00 AM
SE Compensator Installed HD-DOC *General Road Glide Discussions/Pictures 0 08-06-2010 09:41 AM
