Latest SE Comp installed - Road Glide Forums
post #1 of 6 (permalink) Old 07-20-2014, 02:46 PM Thread Starter
FLTR2008Trike's Avatar
I got my 3rd and the newest SE Comp installed. I added the GMR Compusaver oiling tray and Steve @ GMR gave me a PEEK washer to test long term on my trike to replace the bearing washer that comes in the lastest SE Compensator kit. The instruction are not much different from the 1st version SE Comp. You will need a 3/4" torque wrench and a 1 3/4" wrench or a locking wedge bar.
Its been reported that Harley doesnt want the dealers selling the adhesive for the "scoop" that needs to be installed in 2013 and older Big Twin models. HD want the customer to come to the service dept at your local dealer and pay them to install it. Well Im not made of money and most others are not as well. Plus I want to do my own work as much as I can and if you can by the adhesive its $50 from HD.
I got info from another forum that the supplier of the adhesive is Lord and the adhesive is Maxlok MX/T6. You can by the 50ml for $31 which includes shipping and a plastic adapter to use in your caulking gun >> http://www.chembar.com/adhesives/lord-maxlok-mx-t6/
I drilled a few holes in the "scoop to let the adhesive push out and make a better bond with the inside face of the outer primary
The GMR Compusaver oil tray does require that the ribbing be ground out to fit the primary cover over it. The Compusaver tray is a great design to funnel oil into the bore of the SE Comp to keep it well lubricated.
The GMR PEEK washer replaces the stock bearing washer to eliminate any possible bearing failure due to the primary oil has not filtering and will become contaminated with debris and ruin the bearing at some point. I will be checking the washer periodically to see how its wearing for a long term report.
I was able to get in a 120 mile ride today before the thunderstorm and can report a significant reduction in the chattering noise associated with the previous SE Comp. Especially at idle and under load.
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #2 of 6 (permalink) Old 07-20-2014, 02:48 PM Thread Starter
The PEEk Washer and inside of my primary cover grind area
post #3 of 6 (permalink) Old 07-20-2014, 08:29 PM
What was the final cost of the upgrade??
post #4 of 6 (permalink) Old 07-20-2014, 08:46 PM
Subcribing....
Big_gary is online now
post #5 of 6 (permalink) Old 07-22-2014, 03:10 AM Thread Starter
Depending on where you purchase the latest SE Comp it can be higher than what I paid.
I have $500 into it with all parts gasket and oil. The PEEK washer was no charge. Im a tester for long term wear and have to remove it for visual wear and report if there is any. Currently its already looking promising that this will be a better solution than the wafer bearing disk in the new SE Comp version. The short term testing has shown there is small metal particles that will wear the needle bearings in the wafer bearing that comes in the new SE Comp. This of course was done with the setup as it would be installed without the Compusaver oiling tray.
The Compusaver oiling tray has a magnet epoxyed in the tray to help catch the ferrous metal from getting to the needle bearings . It isnt a complete solution to catching the metal but still better than not having it all.
As far as the PEEK washer, it may be out by the end of the year for sale. No info on cost as of yet.
I attached a picture of one with 3k miles on it I got from another forum for a visual reference to the wafer bearing.
post #6 of 6 (permalink) Old 07-29-2014, 02:48 PM Thread Starter
Here is a comprehensive review with 10k miles on the GMR Compusaver oil tray and GMR PEEK washer that was tested in a 2013 trike.
http://www.compensaver.com/study-res...july-2014.html
Installed of SE 254 cams & other SE parts Hillglide Engine Related 2 04-23-2017 12:52 PM
SE Comp Sprocket removal or 2011 models Ronster2 *General Road Glide Discussions/Pictures 4 08-28-2011 01:49 AM
103 high comp build kyjelly44 Engine Related 39 11-06-2010 09:11 AM
96" high comp piston swap?? slowglide2989 *General Road Glide Discussions/Pictures 5 09-02-2010 07:10 PM
2 into 1 pipe for a high comp 103 build...? kyjelly44 Intake and Exhaust 10 03-28-2010 12:42 AM
