.028 spark plug gap in a 2013 fltru! - Road Glide Forums
post #1 of 12 (permalink) Old 07-20-2014, 09:17 PM Thread Starter
Mountainman's Avatar
Send a message via Yahoo to Mountainman
Smile .028 spark plug gap in a 2013 fltru!
My 13 year old son brought me the spark plugs from the bike yesterday during the 5000 mile service and I had him measure them..........
.028
I was completely shocked. I don't believe they have ever been out. If they have been out it was when the moco did the 1000 miles svc, cams and tune/dyno.
Anyone ever tightened up the gap to .028 for a reason?
I set them at .042 and noticed it is idleing AND torqueing up better 2up.
I guess when you buy a new Bike you need to check the basics?
2013 FLTRU Big Blue Pearl:RB Racing LSR Spyder, SE255's (110/95), SERT, Boyesen Power x, DK intake vents,3"tank lift, t-pack relocator, Outlaw oil filter, Slipstream htd grips, l-s mirrors,adj backrest, 3t derby, sancho's wings, Ward's 160* thermostat, BigSky fans, Liquid Moly 10w-60, Rdeline VTwin Heavy Shockproof, B&M Trickshift, Burly ez clutch
Mountainman is offline
post #2 of 12 (permalink) Old 07-21-2014, 07:07 AM
We ALWAYS check the plug gap here.
Never assume they are correct.
Our dyno knowledge has alerted us to .035" on the NGK DCPR8E's we use.
Scott
Hillsidecycle.com is offline
post #3 of 12 (permalink) Old 07-21-2014, 07:41 AM
HUTMO's Avatar
Plug Gap
Scott
Are you saying that 035 is ideal based on dyno experience?
Thanks
HUTMO
HUTMO is offline
post #4 of 12 (permalink) Old 07-21-2014, 12:52 PM
The proper gap is .038 to .043 and according to HD the right plug and plug gap is important for the ION sensing to work correctly with the Delphi ignition system.
The ION sensor replaces the knock sensors HD put in the earlier bikes and it is suppose to help with spark knock by advancing the timing by 4 degrees when the ION sensor detects that the engine is under load or heavy acceleration.
If the bike has spark knock sometimes it will help if the plug gap is wider.
post #5 of 12 (permalink) Old 07-22-2014, 05:48 AM
Originally Posted by hutmo View Post
Scott
Thanks
HUTMO
That is what we've seen with those NGK's we've used since 1999 in the T/C's.
Scott
post #6 of 12 (permalink) Old 07-22-2014, 07:03 AM
twistr's Avatar
Scott
NGK's website recommends a DCPR7E for later model TC's...are you suggesting to use the part number you mentioned. Just curious as I have always used what was recommended, but I will try out the 8E you recommend it. What is the difference between the two?
Riding Life's Twisting Roads...
On a 2008 Dark Blue Pearl Road Glide
twistr is offline
post #7 of 12 (permalink) Old 07-22-2014, 08:16 AM
mocotom's Avatar
The DCPR8E is one step colder heat range plug. The insulator on the colder plug will be slightly larger in diameter and helps to remove the heat from the center electrode which in turn reduces the probability of it becoming a source for pre-ignition. The slightly colder plug works well on correctly tuned motors.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #8 of 12 (permalink) Old 07-23-2014, 06:22 AM
Scott
post #9 of 12 (permalink) Old 07-23-2014, 10:52 AM
laserman's Avatar
Great suggestion, need to look at mine and see if .035 works better then the .040" that they were installed at.
laserman is offline
post #10 of 12 (permalink) Old 07-23-2014, 11:27 AM
mocotom's Avatar
In a stock compression motor the .040 gap will work well, higher comp. motors often prefer the slightly smaller gap. An extreme would be our turbo drag car running 26 lbs of boost the plug gap is set at .018. I realize this is not a motorcycle reference but just trying to provide an example of how comp. affects the ability of the plug to fire the fuel mixture.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
Spark Plug Usage Top Gun *General Road Glide Discussions/Pictures 16 09-24-2017 06:24 PM
Installing New Spark Plug Wires Captain13 Equipment-RG 16 08-23-2013 08:49 PM
Spark Plug pics with FL VIED's one year later CVOVIC *General Road Glide Discussions/Pictures 17 08-27-2012 10:54 AM
Spark Plug issue carcass ECM/Fuel Management systems 6 05-20-2012 09:19 PM
Spark plug wire options abone Aftermarket Accessories 10 09-17-2011 08:39 PM
