se255 cams - Road Glide Forums
post #1 of 8 (permalink) Old 07-21-2014, 01:10 PM Thread Starter
hamer007's Avatar
se255 cams
Don't know if anyone can answer this, my set up is 2012 103ci with highflow air cleaner ,Vance and Hines Power dual and Vance and Hines High output slip ons, power commander V. just had se 255 cams put in. What kind of top end noise should I expect from this set up compared to stock if I have a proper map running, ???
2012 RGU Black,8 inch Klockwerks windshield,
Power Commander V,Vance&Hines Power Duals w/ high Outputs, Screaming Eagle High flow A/C,
PYO 10 inch Monkee Bars and alot of Wille G Skulls
hamer007 is offline
post #2 of 8 (permalink) Old 07-21-2014, 01:41 PM
The 96/103 engines are a noisy engine even when it is stock. The only mod that you made that would produce more top end noise is the cam and I would think that the SE255 cam wouldn't be much noisier than the stock cam.
post #3 of 8 (permalink) Old 07-21-2014, 06:14 PM Thread Starter
hamer007's Avatar
anyone got a proven PCV Map for this set up, that I can try??
hamer007 is offline
post #4 of 8 (permalink) Old 07-21-2014, 06:39 PM
HellInABucket's Avatar
Call Fuel Moto, they will likely give you a map, regardless if you bought it there or not.
HellInABucket is online now
post #5 of 8 (permalink) Old 07-21-2014, 07:39 PM Thread Starter
hamer007's Avatar
already got one from them ,and then a revised version, bought my PCV from them, still not totally happy with it, trying to find someone that has a very accurate map maybe from a dyno to compare it to or try around the block ,see if there is a difference
hamer007 is offline
post #6 of 8 (permalink) Old 07-21-2014, 10:00 PM
I had no change in top end noise on mine after the se255's. However exhaust note was noticeably louder and more reversion noise from the air cleaner, none of which bothers me.
2012 FLTRX
Sideways is offline
post #7 of 8 (permalink) Old 07-22-2014, 05:54 AM
Canned maps are like me trying to wear your pants, and you trying to wear my shoes. No good.
I'd suggest a tune.
Scott
Hillsidecycle.com is offline
post #8 of 8 (permalink) Old 07-29-2014, 02:17 PM
Big Daddy Recon's Avatar
like Hillside said, A canned map is just designed to get you in the ball park. There is nothing that will replace a custom tune. I wrench on bikes everyday and will tell my customers if your doing pipes and air filters yeah of the site tune but once you get into cams or even further Custom is the way to go. Good luck.
2008 Harley FLHTCUI (MABLE) 50k+)
2011 Harley FXDWG (TRADED) 10K miles)
2013 Harley FLTRX (LUCIFER)(DECEASED) last 3 of VIN = 666
Big Daddy Recon is offline
SE255 Cams for sale North Star Parts for Sale 1 06-15-2016 11:55 PM
2012 103", Stage 2, SE255 Cams TLKurtz Dyno Results 17 12-10-2013 05:37 PM
SE255 Cams installed. Dharn55 Engine Related 6 10-07-2013 08:03 PM
SE255 Cams & Dyno Tune TLKurtz Engine Related 8 04-30-2012 09:35 AM
SE255 cams and lifters kevdon Classifieds Archive (3 months old+) 12 04-15-2012 01:08 PM
