Connecting Rod issue - Road Glide Forums
post #1 of 5 (permalink) Old 07-22-2014, 09:14 PM Thread Starter
Deadstroke's Avatar
So the bike is at the shop and there is alot of uneven wear on the cylinder and the top of the connecting rod is purple he said he never saw that before. Concerns are there maybe more damage now and possibly the crank will need to be replaced.
Oil pump is damaged now, looking for another if anyone has any suggestions.
Deadstroke is offline
post #2 of 5 (permalink) Old 07-22-2014, 09:31 PM
pat123's Avatar
If the top of the connection rod is purple that thing got HOT and hot means no oil. Piston oil jet clogged? Check valve stuck? Man that sucks. You need to get your money back from that builder.
pat123 is offline
post #3 of 5 (permalink) Old 07-22-2014, 10:05 PM
mitchdm's Avatar
Deadstroke ~ been down the build road and feel your pain ~ S&S 124 is a cheaper option in the long run, and in my case the short run. Good luck ~ SemperFi
mitchdm is offline
post #4 of 5 (permalink) Old 07-31-2014, 09:34 AM Thread Starter
Deadstroke's Avatar
It was actually cheaper to buy all the parts then to by the motor. Now I dont have a 103 motor to sell but saved a few bucks
2014 - Street Glide - 107 Motor
2015 - Road Glide - Stage 3 Blower Motor & Aerocharger
post #5 of 5 (permalink) Old 07-31-2014, 10:14 AM
There may be a few options you can go with.
You can put in a Darkhorse crank with all the upgrades or you can get a Brand new short block from HD.
The advantage of getting a new short block is you get new cases along with new crankshaft, oil jets, oil pump, cam plate, all timing chains and gears, cam bearings, both cam chain tensioners, crankcase breathers and gaskets. The short block for the 96/103CI touring models HD part #16200070 is only $1,695.
You would need to compare the cost of just doing the crank and getting a new short block but with the other parts that come with the short block it isn't a bad deal.
Shifter arm/rod issue Ibdman21 Troubleshooting for Road Glides 16 07-25-2018 08:55 AM
Connecting ipod (playing and charging to head unit via USB and run inside fairing???? 1extremeskier Audio 6 07-28-2015 06:20 PM
Connecting KMR-M312BT to aswc-1 Mikie Audio 0 07-07-2015 08:31 AM
Carrillo Connecting Rods...... Nevadasun Engine Related 12 02-16-2013 09:30 AM
Connecting a RF 300x4 Amp w/HK radio?? RoadGlide69 Audio 10 02-24-2012 02:38 AM
