96ci Build - Road Glide Forums
post #1 of 10 (permalink) Old 07-24-2014, 03:19 PM Thread Starter
96ci Build
I've got a street glide in my garage as well. I am looking to "Beef" it up a little bit. What do you guys think the best setup for that would be? I'm looking for some well put together options that are "reliable"
My Roadie has Tman setup with 590 cams
platinumnj is offline
post #2 of 10 (permalink) Old 07-24-2014, 03:34 PM
Very open ended question, do you want to go bigger, do you ride 2 up, do you want more speed, more torque, how much are you looking to spend?
post #3 of 10 (permalink) Old 07-24-2014, 04:01 PM
JacktheBagger's Avatar
a tuner such as the TTS and a decent cam like the S&S 551 with a hi flow air cleaner and a good head pipe for starters
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 10 (permalink) Old 07-24-2014, 05:58 PM
Banned
what year & size motor is it now?
PF120 is offline
post #5 of 10 (permalink) Old 07-24-2014, 07:43 PM
HD makes a 103 stage 2 kit which works well but you can go with a 106 or a 107 kit. The kits are a bit spendy IMO, You can call forum member PC Pain at Horny Toad HD and get good prices on the individual parts. I got a brand new set of HD 103 jugs for around $250 shipped to my door and a set of flat top pistons which includes the rings for around $250 shipped, top end gaskets kits go for around $60.
The stock heads will give you plenty of performance so you don't need to waste a lot of money on performance heads.
You can use the same cam that is in the bike and see how you like it, you can also use the same pushrods and lifters. You can alway do a cam and adjustable pushrods later on if you want.
Top ends are a easy DIY and you can do it with basic hand tools with the only specialty tools being a good torque wrench and the HD touring bike service manual and you can save a lot of cash doing it this way.
post #6 of 10 (permalink) Old 07-24-2014, 07:59 PM Thread Starter
Never ride two up on my street glide...more power, speed, and its a 2010 with a 96ci.
I have heavy breather, and screaming eagle race tuner already. and changing to a 2 into one pipe. maybe thunderheader or d&d
post #7 of 10 (permalink) Old 07-25-2014, 05:57 AM
Bore to 107" set @ 10.0 cr.
S&S .570 E-Z Start cams.
Our Stage III Super-Tour Head
58mm S/E, or 58mm S&S t/body.
Point it straight, and let it eat.........
Scott
Hillsidecycle.com is offline
post #8 of 10 (permalink) Old 07-25-2014, 07:47 AM
Banned
a lower compression 107" build with the S&S .570`s is a winner!
PF120 is offline
post #9 of 10 (permalink) Old 07-25-2014, 08:51 AM
My 107 has the 570 cams with just the 50mm tb...... runs great, I would tell you how fast but after 120 the speedo actually drops to 0 and stops working.
post #10 of 10 (permalink) Old 07-25-2014, 10:13 AM Thread Starter
Looks like I'm going to go with the 107 kit and lower compression. Now I need some parts/install prices.....
96ci over the 103ci motor??? 08roady *General Road Glide Discussions/Pictures 17 06-25-2012 10:22 AM
2007 96ci A motor jokercraze Classifieds Archive (3 months old+) 0 05-25-2012 12:12 PM
Dragula and stage (1) 96ci flhr95 Intake and Exhaust 3 04-06-2012 11:39 PM
2011 Road Glide 96ci KevGlide ECM/Fuel Management systems 1 03-21-2012 12:11 AM
RPM @max fuel economy for a stock 96ci BigBadandPlaid ECM/Fuel Management systems 9 09-16-2011 03:59 AM
