117" 103 with 4.125 Bore - Road Glide Forums
post #1 of 6 (permalink) Old 07-25-2014, 07:01 PM Thread Starter
Is anyone running this combination? I know i will need to bore the stock case to accept the bigger bore but is there more than this? I understand the need to do head/cams and such. Anyone running one on the street regularly? I see everyone builds 106/107 but i dont think 3 or 4 cubic inches is worth the money.
Thanks in advance
Chip
Fnhracer is offline
post #2 of 6 (permalink) Old 07-26-2014, 04:50 AM
If your going to stay with stock crank you can bring her up to a 114"
We have several of these and have made 125/128hp128/130 tq
Just my 2 cents
But me Personal for the extra money go with larger crank and 124 if you are in there.
Thanks in advance
Chip
DragoBikeWorks is offline
post #3 of 6 (permalink) Old 07-26-2014, 09:49 AM
mitchdm's Avatar
Heatwave is running an S&S crank & premium Lifters in his 117. You can pm him ~ so far he is pleased.
mitchdm is offline
post #4 of 6 (permalink) Old 07-26-2014, 10:49 PM
MyGlide's Avatar
Built one on my 08 Fatboy I had. Made 138hp/132tq. Got 42-43 mpg cruising 75-80 on the highway. The tune is CRITICAL. It can be a very strong and reliable motor, just depends on how radical you want to go. I would definitely address the bottom end if you decide to go this route.
2018 KTM Super Duke R
MyGlide is offline
post #5 of 6 (permalink) Old 07-28-2014, 06:07 AM
Thanks in advance
Chip
We build these all the time.
A 117" is a formidable power-plant set up correctly.
We have tracked clients with north of 45,000 miles on our 117" combos.
Scott
Hillsidecycle.com is offline
post #6 of 6 (permalink) Old 07-28-2014, 09:02 AM
We are running the S&S 4-3/8 crank and the RP 4.125 cylinders, 'happy so far (6k). A potent sport touring platform that averages almost 40 mpg on the interstate at 80++
HeatWave is offline
M8 117" 10.8:1 big bore Piston & Cylinder kit Fuel Moto fuelmoto Fuel Moto 6 04-03-2019 10:41 AM
Fuel Moto M8 124" big bore kit 114 & 117 engines fuelmoto Fuel Moto 0 01-11-2018 01:09 PM
On order M8 117 Big bore Kit from Fuel Moto steve2100 Engine Related 20 07-29-2017 01:27 PM
Milwaukee Eight Fuel Moto Big Bore Kits 117 120 fuelmoto Fuel Moto 1 04-24-2017 02:03 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 10:31 AM
