120R valve spring pressure - Road Glide Forums
post #1 of 9 (permalink) Old 07-27-2014, 11:37 PM Thread Starter
Exclamation 120R valve spring pressure
Hello all, greetings. I recently purchased a 120r for my 2008 FLTR-ANN. I was worried by the valve spring pressure. It was ~180 closed and 500 on the nose. Shouldn't it be more like 90/280? Also, how good are the rocker arms and lifters? If there is some suggestions and/or recommendations, feel free to comment! Thank you. Tony
jodystony is offline
post #2 of 9 (permalink) Old 08-09-2014, 09:24 PM
bigskyroadglide's Avatar
Guy
I know nothing about what it should be however I spent a considerable amount of time talking with bob wood about his cams and he said I should change the valve springs as well as they have too much pressure.
I am not certain why, but based on my discussion with him and a reputable Indy that has built three of my engines. I'm looking to change them when I change cams
My thoughts
48 states, 19K miles, 23 days
Hoka Hey Rider #622
2011
bigskyroadglide is offline
post #3 of 9 (permalink) Old 08-09-2014, 10:39 PM
Banned
They're on the high side no question. Last set we did we used PAC springs. Did you consider the S&S T124 at all or were you set on the 120R?
INDY #1 is offline
post #4 of 9 (permalink) Old 08-10-2014, 11:41 AM
!85 ft lbs
post #5 of 9 (permalink) Old 08-10-2014, 11:44 AM
I put the HD race valve spring kit in my stock heads and if I remember right the springs are shimmed to 185 ft lbs according to HD specs.
These spring give me a bit more valve train noise but I do get a better more positive valve seat.
post #6 of 9 (permalink) Old 08-10-2014, 01:29 PM Thread Starter
Thanks for getting back to me on this. I purchased a set of AV&V 6500's and thru following an engine builder friend's recipe I should end up with 173# on the seat and 385# on the nose. I hope this solves the inevitable valve train failure based on the ~200# seat and 523# on the nose (measured). I was going to get the S&S 124t, but they were so back ordered I worried about getting my bike done for Vegas bike fest. Also, I live in the "forbidden" state, so I thought I could, with a friend's help who has a cnc machine, transfer my stock case numbers to the 120R with out too much problems. So on to my project...
post #7 of 9 (permalink) Old 08-11-2014, 06:14 AM
Those AV&V springs are nice.
We use a lot of those here.
Another top quality valve spring is those springs that Bob Wood has sourced.
And if under .600" lift, the age-old Crane 1101's are a beautiful set also.
Scott
Hillsidecycle.com is offline
post #8 of 9 (permalink) Old 08-11-2014, 07:46 AM
Banned
good choice,the AV&V 6500`s would be my choice also
PF120 is offline
post #9 of 9 (permalink) Old 08-11-2014, 08:44 AM
Eric Lis's Avatar
Baisleys
Had Dan and Ryan do my heads. Installed all items they suggested and am very happy with results.
1.650 Exh valves
5 angle cut on valves
Springs they suggested
Axtell valve
Lifters they suggested
Adjustable pushrods
Zippers Chain tensioners
Corrected geometry roller rockers
stayed with the 266e cam
pushrod covers
still a little noisy between 22 and 24k rpms but I know the assembly will last
oil pressure runs 22 psi when bike is warm at idle and at cruise it is 45-50psi it will
flux a little on the high end due to the Axtell valve.
Hope this helps anyone looking to improve the 120R MVA heads
Eric Lis is offline
Tags
se 120r
Stock Valve Spring limit? smajr85 Engine Related 4 11-12-2015 07:09 AM
Broke valve spring exracer2002 Do-IT-Yourself 3 04-19-2014 08:17 PM
Clutch for 120R bigtwin Engine Related 3 02-15-2011 08:52 AM
Pcv map for 120R bigtwin ECM/Fuel Management systems 0 11-12-2010 11:49 PM
SE 120r NakedSnowman Engine Related 22 10-13-2010 01:43 PM
