carbs and cable - Road Glide Forums
post #1 of 5 (permalink) Old 07-29-2014, 07:25 AM Thread Starter
carbs and cable
I'm getting fed-up with TBW issues on my 2012 FLTRX and I also wonder if using carbs will make her sound better. Two questions 1)Can I get rid of the TBW and put a cabled-throttle on without having to do anything else such as get rid of the fuel injection and 2) If I did want to get rid of the fuel injection and get carbs are there kits specifically for my bike to do this? What's involved? What kit to get?
Anyone here to do this?
palmpalm is offline
post #2 of 5 (permalink) Old 07-29-2014, 03:53 PM
JacktheBagger's Avatar
it can be done
it can get pretty involved
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 5 (permalink) Old 07-29-2014, 04:05 PM
RoadGlideRider's Avatar
If you check the Dyna and the Softail, I believe they are still using cables.
That is better than going back 6 years to try to add out dated Touring equipment.
But I haven't ever had any problems with my TBW. I have even changed my handlebars.
RoadGlideRider is offline
post #4 of 5 (permalink) Old 07-29-2014, 09:15 PM Thread Starter
What would be involved in removing the TBW system and putting a cable on instead?
palmpalm is offline
post #5 of 5 (permalink) Old 07-30-2014, 12:44 AM
Well, to start you need a big bank. It will cost to change. Anything can be done with enough money.
Next, you would need service manual and part catalog for both your bike and the year of the parts you change too. This way you get the correct parts.
The basic parts start with the ECM, manifold, sensors, cables, chock, harnesses, brackets, and assorted nuts and bolts. The books will give specific parts and numbers needed.
In reality, it would cost less to sell yours and buy an older model without TBW.
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 09:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 06:42 PM
2012 CVO Bars, ABS Brake Cables and Clutch Cable jkpoppe Classifieds Archive (3 months old+) 3 10-08-2012 12:07 AM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 05:08 AM
throttle cable handlebars and tbw handlebars Swagzilla Controls & Handlebars 2 01-30-2012 08:30 PM
