Id like some cam advice - Road Glide Forums
post #1 of 45 (permalink) Old 07-30-2014, 02:53 PM Thread Starter
BigNorm's Avatar
Im considering getting into the motor finally after owning my 2011 RGU since it was new in July 2011 when I bought it. I ride pretty mild most of the time as its my daily driver but i notice the power loss when my wife rides with me. We probably have 550 between us rider and passenger. Im also considering towing a trailer with the bike for longer excursions. I like to shift it around 3200 rpm. 4000 on occasion when im riding with the fellas but day in and out Im taking it easy. So id like a cam that produces a lot of torque in the low range. The stock 5000 rpm redline is fine with me. Im not looking to blow it apart. Thanks. NORM
BigNorm is offline
post #2 of 45 (permalink) Old 07-30-2014, 03:02 PM
JacktheBagger's Avatar
S&S 551
JtB
2011 Ultra
JacktheBagger is offline
post #3 of 45 (permalink) Old 07-31-2014, 09:07 PM
boomerman's Avatar
I think I would look at all the manufactures offering and see what they have to offer.
There are some great cams out there and we all have our favorites.
I would also consider new lifters and push rods as well.
2012 Road Glide Ultra Big Blue Pearl
1999 Dyna SuperGlide Black
boomerman is offline
post #4 of 45 (permalink) Old 07-31-2014, 09:30 PM
faststan's Avatar
I've got SE 255's in mine. I ride some what like you do and they suit me fine. As far as H_D the se 254e is another good cam.
Check with Jon @ horny toad H_D he gave me a good deal on my cams, lifters, bearings ans push rods.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #5 of 45 (permalink) Old 07-31-2014, 09:49 PM
pacfan1967's Avatar
I have the se255s and it pulls good at lower RPMs. However, I also did the screaming eagle pro racing stage 3 and head work at the same time so I'm not sure what just adding the cams will do.
Ride safe, Gary
pacfan1967 is offline
post #6 of 45 (permalink) Old 07-31-2014, 10:17 PM
panhead's Avatar
The 255 se cams run hotter but do produce nice torque.I had them in my old bike but switched to the tman 555 torquer cams.the tman pull just as well and run cooler. better on hot starting too.the differences are in the valve overlap.good luck.
2011 COOL BLUE PEARL FLTRX , 120R,
too much to list...
panhead is offline
post #7 of 45 (permalink) Old 08-01-2014, 05:47 AM
Andrews 48 or a Wood 222.
Scott
Hillsidecycle.com is offline
post #8 of 45 (permalink) Old 08-01-2014, 10:43 AM
equandt's Avatar
Scott
I have the TW-222 in my RGC and love it. It makes great torque right where the OP described. For a cam only application, the TW-222 is a great choice. I've been very happy with mine.
2012 FLTRX
2010 FLHTCU
equandt is offline
post #9 of 45 (permalink) Old 08-02-2014, 09:49 AM
Road dawg's Avatar
Im running a feuling 525 reaper cams pulls hard on the low end love em, I never shift higher than 5k ,noticeable low end pull especially when riding two up with my tour bag, good luck.
Road dawg is offline
post #10 of 45 (permalink) Old 08-02-2014, 10:41 AM
The Woods TW 222 is a real stump puller, it has great torque from 2000 to 5000 rpm. I run the SE 255 before and the TW 222 beats the SE 255 cam hands down. JMO
Need some help with a part ID jayfire *General Road Glide Discussions/Pictures 5 07-23-2014 04:21 PM
I like the way the 30 looks like its spinning backwards.... Quicksand General Off-Topic Discussions 8 12-24-2012 02:06 PM
TC88 Cam/Cam tensioner advice zglide2003 Engine Related 2 08-31-2012 12:01 PM
Cam upgrade... Need some advice NTEXRG Engine Related 9 04-16-2012 10:10 AM
Help with wire ID HD_Shock *General Road Glide Discussions/Pictures 4 03-28-2011 11:34 AM
