Clutch assy - Road Glide Forums
post #1 of 9 (permalink) Old 08-07-2014, 06:07 PM Thread Starter
GroundPounder's Avatar
Clutch assy
Need advice on a reliable clutch setup ( hub, basket and plates) for a high torque 117" engine build... Se plates in it now with stock basket and hub, but I don't trust the basket and hub to hold together....looking at revera primo and Barnett, any suggestions greatly appreciated.. Thx guys....
2011 Vivid Black RG Custom, 117ci, Yaffe bars, D D Boarzilla, Alpine PDX F-6, 6.5 Alpine R's up front (4) and 6x9 R's in bags, Paul Jr- Rapture Wheels 23/17, monotubes w/ 1" drop, SMT contrast boards and bag latches, Daymakers. 6* PICKARD TREES, rides like its on rails....I'm through, not spending another dime....
GroundPounder is offline
post #2 of 9 (permalink) Old 08-07-2014, 07:16 PM
FrankieB's Avatar
I have a primo pro clutch with their VPP in my road king, it puts down 140 squared.
06 RK
11 RGU
FrankieB is offline
post #3 of 9 (permalink) Old 08-07-2014, 08:48 PM
Hullhorr's Avatar
I also have the Rivera Primo and really like it. Based on the reviews I looked at it is a coin toss between Rivera Primo and Barnett. I think you will be pleased with either one.
2009 FLTR MOP
Hullhorr is offline
post #4 of 9 (permalink) Old 08-08-2014, 02:05 AM
Banned
Evolution Industries (Diamond Ternimator.) They make parts for Primo, AIM and more. Why not go straight to the source?
INDY #1 is offline
post #5 of 9 (permalink) Old 08-08-2014, 06:52 AM
Of all the big engines we build, never had a clutch basket come unglued.
Look no father than a VPC 92T with a Barnett spring.
Scott
Hillsidecycle.com is offline
post #6 of 9 (permalink) Old 08-08-2014, 01:59 PM
Barnett scorpion here.
Do yourself a favor and buy the clutch lock plate. You'll need it to properly torque the nut on the mainshaft. http://www.barnettclutches.com/clutch-lock-plate.html
Clutch grabs & holds great, hooks up noticeably better than it did with the SE clutch and heavy spring that was in there from day one.
2011 RG Custom, Screaming Eagle Stage IV (260 Cam), Barnett Scorpion clutch, Hayden M6, Baker DD7, V&H Throttlepak, V&H Power Duals w/Hi-Output Slipons
115.4 ft-lb & 122.7hp : 1/4 Mile 12.542 @ 105.99 w/stock clutch and transmission
gbourdon is offline
post #7 of 9 (permalink) Old 08-14-2014, 09:51 AM
+1 on the Evolution. Flawless in my build, 2 other big inch builds my mechanic did that are 140+HP have the same result...very nice clutch.
107 w/ T-Man cylinders and pistons, Zipper's stage 3 heads, Feuling 594 reaper cams, HPI 58mm elliptical TB, S&S roller rockers+forged shafts+premium lifters, TMax, D&D, S&S cam plate+pump, Evolution clutch+no comp sprocket, Baker chain tensioner, bottom end by Revolution w/H beams+Timken, Jagg w/fan, Baker DD7 & +1.5 pan, 14" Vindikta bars, Legend Axeo cartridge forks+Revo-A, HD Blade 18+18, Daymakers, Russell Day-Long.
G Ogre is offline
post #8 of 9 (permalink) Old 08-14-2014, 08:34 PM
BlownBagger's Avatar
I run an Aim CF2 Second Generation.When you get into the big horsepower it just makes sense to run the good stuff.They are alittle expensive but broken cranks are even more expensive.A cast aluminum basket is a disaster looking for a place to happen in a big horsepower build.
_
BlownBagger is offline
post #9 of 9 (permalink) Old 08-15-2014, 11:07 AM Thread Starter
Thanks for the feedback, guys....I ordered the Scorpion, due in Monday....
2009 and newer low sissy bar/pad assy. panhead Sold 2 03-20-2013 08:35 PM
Headlight assy w/ hid setup GroundPounder Parts for Sale 1 02-26-2013 04:20 AM
Headlight assy removal on 2012 help ReferJohn Lighting 3 08-03-2012 12:40 AM
New clutch assy. - cant adjust freeplay from cable Sincecrazy Troubleshooting for Road Glides 9 09-04-2011 09:40 AM
assy swith on dash spshult *General Road Glide Discussions/Pictures 4 07-09-2011 09:24 PM
