Can a 103 cylinder be bored to a 106/107 - Road Glide Forums
post #1 of 5 (permalink) Old 08-11-2014, 11:04 AM Thread Starter
I got a set of 103 cylinders that already been bored .010 over and I was thinking about boring them out to 106 or 107. Has anyone done this and is the 103 cylinder walls thick enough to be bored to 106/107?
post #2 of 5 (permalink) Old 08-11-2014, 11:32 AM
pat123's Avatar
103 bore plus .010 = 3.885
106 bore 3.927
107 bore 3.938
You have plenty of meat left to bore
pat123 is offline
post #3 of 5 (permalink) Old 08-11-2014, 11:51 AM
Bull_Duck's Avatar
Like you, I have an '08. You are considering going to a 107" by way of your temporary stop at. 103".
I've been considering jumping straight into 107".
Bull_Duck is offline
post #4 of 5 (permalink) Old 08-11-2014, 10:32 PM Thread Starter
Not sure if I want to go with a 106/107 yet. I just put on new 103 cylinders not to long ago but these cylinders are just sitting here and since they are already .010 over I would have to hone them to reinstall which may make them a bit too big. Boring them to a 106/107 would be the best so I can use them the next time I freshen the top end or if I want to sell the cylinders it would be easier.
post #5 of 5 (permalink) Old 08-12-2014, 05:52 AM
Yes, we've bored those to 107" many times here.
Scott
Hillsidecycle.com is offline
WTB: front brake master cylinder/clutch master cylinder 93-331-29psi Wanted! (Buy or Trade) 3 09-26-2014 03:46 PM
S&S Hp-103 cams in a 106" gabbyduffy Dyno Results 2 09-10-2014 11:11 PM
CVO Hydraulic Clutch Cylinder and Master Cylinder. tech643 Parts for Sale 3 04-29-2014 01:07 PM
PV map for 106/107 kit, 57H cams and heads mffi497 Map Section 1 11-25-2013 10:00 AM
