Fuel mileage drop - Road Glide Forums
post #1 of 11 (permalink) Old 08-17-2014, 02:29 PM Thread Starter
1st Sgt's Avatar
Fuel mileage drop
So over the past year my fuel mileage has decreased 10%; from an average of 43 MPG down to 37 MPG. Anything I should look at as an impending failure?
1st Sgt is offline
post #2 of 11 (permalink) Old 08-17-2014, 03:17 PM
Wrist movement .
post #3 of 11 (permalink) Old 08-17-2014, 04:47 PM
thedrill's Avatar
Originally Posted by Big_gary View Post
Wrist movement .
+1
2012 Road Glide Ultra, 1978 Honda XL125, 1992 Suzuki DR350
thedrill is offline
post #4 of 11 (permalink) Old 08-17-2014, 05:14 PM
93-331-29psi's Avatar
How many miles? First thought would be plugs and fuel filter, but could be result of a quick snappy wrist.
93-331-29psi is offline
post #5 of 11 (permalink) Old 08-17-2014, 06:27 PM
ERod62's Avatar
Running to higher RPM between gear changes? Lots of revs up? More items on bags weight increase?
Assuming everything else is normal.
ERod62 is offline
post #6 of 11 (permalink) Old 08-17-2014, 09:34 PM
Mountainman's Avatar
Send a message via Yahoo to Mountainman
Question Fuel?
Has your fueling location changed?
Has your fuel gone from no ethanol to 5% to 10% to 15% ethanol?
2013 FLTRU Big Blue Pearl:RB Racing LSR Spyder, SE255's (110/95), SERT, Boyesen Power x, DK intake vents,3"tank lift, t-pack relocator, Outlaw oil filter, Slipstream htd grips, l-s mirrors,adj backrest, 3t derby, sancho's wings, Ward's 160* thermostat, BigSky fans, Liquid Moly 10w-60, Rdeline VTwin Heavy Shockproof, B&M Trickshift, Burly ez clutch
Mountainman is offline
post #7 of 11 (permalink) Old 08-17-2014, 10:11 PM
RoadGlideGary's Avatar
^+++ all of the above. Sounds like you are experiencing happy riding and potentially crappy (seasonal) fuel. Might want to check your air filter too along with tire pressure.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #8 of 11 (permalink) Old 08-18-2014, 11:47 AM
You're not coasting down those long Arizona downhill grades anymore. You need more throttle to cruise on the flatland.
post #9 of 11 (permalink) Old 08-18-2014, 02:21 PM
tdkkart's Avatar
10-15% ethanol will do exactly what you are describing, I saw it several times on the way to SWIV as I went state to state and used fuel with and without ethanol. MPGs ranged from 36-43.
tdkkart is offline
post #10 of 11 (permalink) Old 08-18-2014, 02:45 PM
tmd
Welcome to the wonderful world of Ethanol.
tmd is offline
110 drop in, CVO w/Mods, 117 drop in Lou Dude Dyno Results 1 03-08-2017 08:59 AM
Fuel Mileage K-Dub Fuel Moto 9 08-05-2015 03:48 PM
Drop-in kit, is it really a drop in? Transporter Suspensions 10 01-29-2015 01:22 PM
fuel mileage surprise JacktheBagger Road Glide Specific Discussions 33 02-20-2012 04:17 PM
Fuel Mileage report after intake and remap SquirtRGU Road Glide Specific Discussions 11 05-22-2011 02:10 AM
