Engine skips on roll-on after deceleration intermittently. - Road Glide Forums
post #1 of 5 (permalink) Old 08-17-2014, 06:26 PM Thread Starter
KiloGolf4's Avatar
Question Engine skips on roll-on after deceleration intermittently.
New to me 2011 RGC 103 w/13.8kmi. Has hd stg1, decatted w/4" Rineharts, and TTS Mastertune done by the PO.
Pretty sure this only happens right after using engine braking in deceleration, just at the dead spot on roll-on, the engine sounds like (and is) it's running on one cylinder for a full second maybe 3-4revolutions. Doesn't happen every time but short or long decel makes no difference. Pulled the plugs today and they are fine with good color. Hot or cold makes no difference. The other day it did it mid-turn, coughed a backfire, but caught up before cutting off and again took the fuel without another miss.
It's starting to get into my head on turn in and I am second guessing corners making me unstable. Anyone have a similar problem that can point me in a direction?
"Behold, I stand at the door and knock. If any man hear my voice and open the door, I will come into him and sup with him and he with me." Jesus, Revelation 3:20
KiloGolf4 is offline
post #2 of 5 (permalink) Old 08-18-2014, 09:05 PM Thread Starter
KiloGolf4's Avatar
Hmm....no one has any thoughts on this problem?
post #3 of 5 (permalink) Old 08-18-2014, 09:51 PM
It's needs to go back on Dyno sounds like you have some lean spots it should not cough when you roll into it..
DragoBikeWorks is offline
post #4 of 5 (permalink) Old 08-18-2014, 10:28 PM
tdkkart's Avatar
Deceleration really cleans the fuel out of the cylinders, which means it will hiccup when you pick up the throttle. Richen the idle mixture or the decel enrichment numbers a touch u ntil it clears up.
tdkkart is offline
post #5 of 5 (permalink) Old 08-19-2014, 10:53 PM Thread Starter
KiloGolf4's Avatar
Ok, sounds plausible. Now just need to find a tuner to do that. Thanks!
When Rock & Roll was Rock & Roll SteadyEddie General Off-Topic Discussions 85 11-12-2017 03:21 PM
Power Vision works intermittently elbohead ECM/Fuel Management systems 7 05-27-2015 11:00 AM
Roll tide roll Big_gary General Off-Topic Discussions 14 01-11-2013 01:42 AM
Cruise control working intermittently? motodrummer Controls & Handlebars 4 03-23-2012 08:31 AM
Engine "shudder" during deceleration shock513 Road Glide Specific Discussions 8 09-26-2011 10:43 PM
