low oil pressure - Road Glide Forums
post #1 of 6 (permalink) Old 08-17-2014, 08:49 PM Thread Starter
Boogitybob's Avatar
low oil pressure
After passing 15k I have noticed my oil pressure at idle when fully warmed up is only about 7 psi Is this normal on a stock 103 Sure makes me nervous. At speed 2200 rpm and above pressure is 32 psi. I ve tried both synthetic and synthetic blend and see no change in pressure'
THANKS
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
post #2 of 6 (permalink) Old 08-17-2014, 08:55 PM
pat123's Avatar
Normal.
pat123 is offline
post #3 of 6 (permalink) Old 08-17-2014, 09:24 PM
Mountainman's Avatar
Send a message via Yahoo to Mountainman
Smile Oil pressure?
What is the engine oil temp? What weight of oil are you using? How many miles on the oil?
Your numbers are fine and normal. You can install this to increase pressures at idle. http://www.axtellsales.com/Axtell-bypass-system.html This product WILL make a difference.
If you are worried about the low pressure at idle lowering oil temps can help:
If you are in a 90* plus temps and have oil temps over 230* you might think about going to a heavier weight of oil, adding cooling fans to your oil cooler to lower temps and getting your tune squared away as that will also help the oil temp.
2013 FLTRU Big Blue Pearl:RB Racing LSR Spyder, SE255's (110/95), SERT, Boyesen Power x, DK intake vents,3"tank lift, t-pack relocator, Outlaw oil filter, Slipstream htd grips, l-s mirrors,adj backrest, 3t derby, sancho's wings, Ward's 160* thermostat, BigSky fans, Liquid Moly 10w-60, Rdeline VTwin Heavy Shockproof, B&M Trickshift, Burly ez clutch
Mountainman is offline
post #4 of 6 (permalink) Old 08-17-2014, 10:06 PM
Originally Posted by pat123 View Post
Normal.
+1. Mine is the same
rlaf75 is online now
post #5 of 6 (permalink) Old 08-17-2014, 10:25 PM
RoadGlideGary's Avatar
Had a similar issue. Went to straight syn50 and it now drops to 15/17 at idle at steady 32 at operating rpm. All good.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #6 of 6 (permalink) Old 08-17-2014, 11:05 PM Thread Starter
Boogitybob's Avatar
THANKS GUYS not crazy about it but glad to hear nature of the beast
BoogityBob
Low Oil Pressure Indication woverby Engine Related 9 12-05-2017 06:12 PM
Low oil pressure/enginge problem? Rockinjoe1 Engine Related 9 06-27-2016 02:17 PM
Extreme Low Oil Pressure Hannibal Engine Related 16 05-14-2014 09:23 PM
Low Oil Pressure And Noisy Tranny chkywuky Troubleshooting for Road Glides 4 09-18-2013 12:29 AM
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 10:44 AM
