Broke another transmission. I suck - Road Glide Forums
post #1 of 10 (permalink) Old 08-20-2014, 10:12 AM Thread Starter
Thumbs down Broke another transmission. I suck
So in my other thread i have the pictures of my mangled second gear. Totally due to user abuse in my opinion.
Swapped it out for a used 2007 streetglide transmission that i got on ebay. used the baker high torque bearing for the install since it had the 2007 main shaft.
I noticed some skipping out of third in the transmission but rode around it, skipping over third. Assumed it was a dog gear or shift fork that was worn. My plan was to pull the transmission out and use parts of the other transmission that i removed, if serviceable, to solve the third gear issue.
On the way to work the other day I rapped the throttle in second gear and kaboom! Gear noises, bad gear noises. I was only half a mile from home so I limped in riding it in 4th or 5th. Seemed like the least amount of noise in those gears.
Last night i pulled out the transmission again to see how bad it was and found i broke the trap door. Also interesting to see that the nut is no longer on the counter shaft. Cool.
2011 RG Custom, Screaming Eagle Stage IV (260 Cam), Barnett Scorpion clutch, Hayden M6, Baker DD7, V&H Throttlepak, V&H Power Duals w/Hi-Output Slipons
115.4 ft-lb & 122.7hp : 1/4 Mile 12.542 @ 105.99 w/stock clutch and transmission
gbourdon is offline
post #2 of 10 (permalink) Old 08-20-2014, 10:16 AM
Bummer! Looks like that DD7 is coming sooner than expected.
post #3 of 10 (permalink) Old 08-20-2014, 10:28 AM Thread Starter
I know. I should have ordered it in the first place. I'm like $600 into this fiasco already with the transmission, fluids, gaskets, etc.
Good news is i can have my transmission out of the bike and on my workbench in about an hour now.
I just got off the phone with baker, DD7 promotion right now, including tool rental, gaskets, mainshaft bearing, etc. for $2995
gbourdon is offline
post #4 of 10 (permalink) Old 08-20-2014, 03:10 PM Thread Starter
Baker DD7 and Hayden M6 ordered and on the way.
I also bought the baker main drive bearing tool.
gbourdon is offline
post #5 of 10 (permalink) Old 08-20-2014, 03:35 PM
DD6 is stronger.
DragoBikeWorks is offline
post #6 of 10 (permalink) Old 08-20-2014, 04:01 PM Thread Starter
I was considering the DD6 too. Its a little bit cheaper than the DD7, wasn't sure if that would fit in the case or if i would then need an older case. I'm looking forward to the different gear ratios, i was going to change my pulley.
I'm thinking that I need to chill out on dropping the clutch and going down the road sideways.
gbourdon is offline
post #7 of 10 (permalink) Old 08-21-2014, 12:29 AM
Banned
OD 6 is the strongest of the bunch from Baker and the tool is considerably less money from George's Garage and they're excellent tools. I think I have about every tools they make. In all honestly though, the Baker Street Door and Haevy Duty throwout bearing should be more than strong enough for the power in your signature and way less money. The Hayden doesn't fare well either with the big power output. The Baker Attitude adjuster seems to be the best option or taking the stock unit and welding it so it can't continually ratchet up tighter and wipe out bearings.
INDY #1 is offline
post #8 of 10 (permalink) Old 09-15-2014, 01:26 PM Thread Starter
Baker DD7 is installed and bike is running great.
Gearing is finally the way it should have been. Logged about 300 miles over the weekend. Its done, i'm happy.
Just a little lighter in the wallet than I wish.
gbourdon is offline
post #9 of 10 (permalink) Old 09-15-2014, 02:09 PM
Bruce00's Avatar
I realize that this was an older thread, but you where killing your trans with 115 ft lbs? Bummer to read of your troubles, but you got it licked now!
Bikeless
2015 RoadGlide Special--RIP
Tuned by Jamie @ Fuel Moto w/Rinehart 2>1
Bruce00 is offline
post #10 of 10 (permalink) Old 09-15-2014, 03:06 PM Thread Starter
I think the stocker only liked so much abuse. I dont think the amount of power being put to the ground is what cost me the transmission.
It lived a hard life of power shifting and rolling burnouts.
gbourdon is offline
Another transmission fluid transfer thread geo8866 *General Road Glide Discussions/Pictures 98 02-09-2019 12:02 PM
Another transmission problem need help on blackbart36350 Troubleshooting for Road Glides 18 09-30-2013 01:48 PM
another transmission cluunk thread kentucky cowboy Troubleshooting for Road Glides 21 03-09-2013 07:52 PM
Avon grips suck? Yes no maybe? Blackrg Controls & Handlebars 12 08-30-2011 09:09 AM
Gravity can suck Mikey Rod *General Road Glide Discussions/Pictures 42 05-02-2011 05:57 PM
