help..... no oil pressure - Road Glide Forums
post #1 of 8 (permalink) Old 08-22-2014, 09:24 PM Thread Starter
Just changed out cams in my 12 rg from 777 to tw8-6 and now have no oil pressure. Competed install and fired up first time seen it had no pressure and shut down and thought. Only thing I could do is take it all back apart and inspected everything found nothing. Replaced all O-rings again for good measure and reassembled with same results. Even tried pressurizing crank case to no avail. On way home got thinking maybe sender is bad will check that tomorrow but I aint that lucky lol. Any ideas or insight would be appreciated as I'm fresh out of them.
drnovaman is offline
post #2 of 8 (permalink) Old 08-22-2014, 09:37 PM
TimmyG's Avatar
Is there oil in it?
TimmyG is offline
post #3 of 8 (permalink) Old 08-22-2014, 09:53 PM Thread Starter
yes good question though sometimes its easy to overlook the obvious.
post #4 of 8 (permalink) Old 08-22-2014, 10:36 PM
Hullhorr's Avatar
Check the relief valve and relief spring in the cam support plate. They have been known to go bad. I would also make sure you have the oil pump aligned correctly with the lobes on the crankshaft if you removed it when you did your cams.
2009 FLTR MOP
Hullhorr is offline
post #5 of 8 (permalink) Old 08-23-2014, 05:15 AM
FrankieB's Avatar
^^^this and also if you took the oil pump off, make sure the oil pump pieces were put back on in the correct order.
06 RK
11 RGU
FrankieB is offline
post #6 of 8 (permalink) Old 08-23-2014, 06:00 PM Thread Starter
we have a winner feel like a dumb ass but its all good now. I guess sometimes one should look at the pictures.
post #7 of 8 (permalink) Old 08-23-2014, 08:05 PM
staush's Avatar
Oil pressure
Ok (winner that feels like a dumb ass) we've all been there. What was it, oil or bad assembly?
staush is offline
post #8 of 8 (permalink) Old 08-23-2014, 10:15 PM
FrankieB's Avatar
I am guessing the wavey washers where put in the wrong order.
06 RK
11 RGU
FrankieB is offline
NO OIL and no idiot light?? motodrummer Troubleshooting for Road Glides 16 06-18-2015 10:48 PM
Help Oil Pressure cdc3660 Engine Related 12 04-06-2014 11:21 AM
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 10:44 AM
No oil pressure Double0 Troubleshooting for Road Glides 12 09-19-2012 12:03 AM
Oil pressure gauge 2010fltrx Troubleshooting for Road Glides 1 08-16-2010 04:09 PM
