Motor noise - Road Glide Forums
post #1 of 12 (permalink) Old 08-23-2014, 09:27 AM Thread Starter
Motor noise
2011 RG 13000 miles on it when I start is top end makes noise like no oil warm it up and goes away but if I throttle up hard sounds like the valves are hitting the bottom of the gas tank HELP Just pipes remap and air cleaner on it motor never been apart
Whitehairedpete is offline
post #2 of 12 (permalink) Old 08-23-2014, 09:42 AM
Hullhorr's Avatar
My guess would be the one or more lifters are bleeding down and take a few minutes to pump back up. The stock lifters are not the best.
2009 FLTR MOP
Hullhorr is offline
post #3 of 12 (permalink) Old 08-25-2014, 03:40 AM
Yep, sounds like the stock lifters are doing what they do, it seems more often than not...
Dfwhockey17 is offline
post #4 of 12 (permalink) Old 09-01-2014, 11:24 AM
Don't ignore it. Get it checked out. Mine started doing that and I ended up having to get total motor rebuild. Comp also went out and I ended up with only my old engine cases and heads remaining. Everything else was replaced, luckily under ESP. Good Luck!
1 HD ULTRA is offline
post #5 of 12 (permalink) Old 09-01-2014, 11:31 AM
Road dawg's Avatar
+1 happened to my 2011 fltrx at 11k POS factory lifters, now im running S&S premium lifters no more problems.
Road dawg is offline
post #6 of 12 (permalink) Old 09-01-2014, 10:26 PM
Boogitybob's Avatar
What options are out there for lifters I see S&S mentioned What are advantages of these lifters Thanks
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
post #7 of 12 (permalink) Old 09-01-2014, 11:19 PM
When I had to replace my lifters I went with Fueling. There fine and doing the job however, I wish I had went with S&S premium. Tom Wood makes a good lifter, also.
post #8 of 12 (permalink) Old 09-02-2014, 09:34 AM
Yes, I would definetly go with S&S or Fueling lifters. Ever since Johnson quit making the HD lifters way back, the HD lifters haven't been what they should be. It's kinda rare that one would go out at such low miles, but it's DEFINETLY not un-heard of!
Legacy roadglide is offline
post #9 of 12 (permalink) Old 09-02-2014, 11:39 AM
"It's kinda rare that one would go out at such low miles".......mine started going out a 7k miles.
post #10 of 12 (permalink) Old 09-04-2014, 06:56 AM
If in fact the lifter(s) is bleeding off, then look no further than an S&S unit.
We have used NOTHING but those here since the mid 1990's.
Scott
Hillsidecycle.com is offline
Motor Noise Bluchevypick Engine Related 15 07-14-2013 10:48 AM
Hissing noise in motor????? Louster47 *General Road Glide Discussions/Pictures 15 05-11-2013 09:23 AM
motor noise xbohntr Troubleshooting for Road Glides 23 03-04-2013 12:13 PM
motor noise xbohntr Troubleshooting for Road Glides 4 02-28-2013 08:47 PM
HELP! New and odd motor noise! bad86ta *General Road Glide Discussions/Pictures 1 05-30-2012 08:42 PM
