se compensator - Road Glide Forums
post #1 of 5 (permalink) Old 08-24-2014, 12:39 PM Thread Starter
se compensator
What year did Harley start putting the se compensator in from factory?? Is the bdl or vulcanworks a cure all??? I have a 2012 rg with 42 K no problems as of yet but don't want to be left on that lonely highway. Any input much appreacheated
craig demel is offline
post #2 of 5 (permalink) Old 08-24-2014, 03:12 PM
ERod62's Avatar
Think was 2012.
Here is a thread about other brand choices. Seen like choices aren't any better.
https://www.roadglide.org/showthread.php?t=162241
ERod62 is offline
post #3 of 5 (permalink) Old 08-27-2014, 08:59 AM
equandt's Avatar
2011 was the first year for the SE compensator from the factory. I upgraded my 2010 FLHTCU the to the 2011 SE compensator. My 2012 FLTRX has been fine.
2012 FLTRX
2010 FLHTCU
equandt is offline
post #4 of 5 (permalink) Old 08-27-2014, 09:15 AM
I can't speak of the vulcanworks sprocket but I recently installed the BDL and it's making a hell of a racket when it's hot. I know MikeU also installed the BDL and he's having problems too. I heard some who use it have good reviews of it and my bike does run great with it other than the noises im getting. Here's a thread I started about the BDL you may want to read https://www.roadglide.org/showthread.php?t=162241
post #5 of 5 (permalink) Old 08-27-2014, 02:30 PM
glide69's Avatar
I just put the VulcanWorks sprocket on mine and like it. I have a different noise now but I believe its from the Hayden tensioner that I installed at the same time. The Hayden tensioner has a lot less surface area then the stock unit and works vertical as where the stock one is more at a angle. If you already have the SE compensator you will need a spacer that is not supplied as of yet with the sprocket. This is being addressed with VulcanWorks. I sent them my old SE comp so they can take the measurements so the can include a spacer. I used a 3/16" spacer on mine.
2018 FLTRXS Wicked Red
glide69 is offline
New Compensator or Compensator eliminator mrmoto95 Engine Related 11 03-28-2018 08:10 PM
Harley's "SE" Compensator,....Why? Nevadasun Engine Related 14 08-07-2013 01:13 AM
Wtb se compensator 40274-08a RoadGlide0611 Wanted! (Buy or Trade) 3 10-23-2012 08:31 AM
SE Compensator?!?! longrides *General Road Glide Discussions/Pictures 21 09-28-2012 02:23 PM
SE Compensator Installed HD-DOC *General Road Glide Discussions/Pictures 0 08-06-2010 09:41 AM
