help with pinging noise - Road Glide Forums
post #1 of 4 (permalink) Old 08-24-2014, 08:37 PM Thread Starter
Question help with pinging noise
hi any help would be great have notice pinging when in 5th and 6th when I roll on the gas to pass on the freeway it goes away have also got 91 octane
in it ,power commander 5 filter woods 777 and a thunder header ,pulls
strong but that hesitation and ping noise is driving me nuts
bigmatt1967 is offline
post #2 of 4 (permalink) Old 08-24-2014, 09:29 PM
mitchdm's Avatar
You can retard the timing with the PCV. You'll have to go into the ignition tables to retard it. Dropping it 5 degrees in the problem area is where I would start.
mitchdm is offline
post #3 of 4 (permalink) Old 08-26-2014, 05:29 PM
I'm having the same problem, different cams exhaust and tuner
13 black fltrx 103, sert, se255 cams, vance & hines power duels, cfr mufflers, 14" pm bars, 21" pm wrath front 18" rear and the list goes on
schlum13 is offline
post #4 of 4 (permalink) Old 08-29-2014, 06:45 AM Thread Starter
Smile
So got the fix from fuelmoto
they changed the map at the point of the ping a bit more fuel
problem solved 99% just a very slight ping ,much better
Pinging Eliminated lldsilver41 ECM/Fuel Management systems 17 08-05-2013 08:47 PM
Pinging when hot, what to tell the dealer? DakotaRob Troubleshooting for Road Glides 30 06-25-2013 12:25 AM
Definition of "Pinging" please ChivoChavez321 Troubleshooting for Road Glides 10 12-07-2012 06:25 PM
No pinging!!! 1st Sgt Dyno Results 0 10-28-2012 12:23 AM
Possible Detonation & or pinging mdwar2005 Troubleshooting for Road Glides 1 07-24-2011 09:08 PM
