Help sorry this was posted in the wrong forum earlier - Road Glide Forums
post #1 of 3 (permalink) Old 08-25-2014, 04:43 PM Thread Starter
I just installed a COBRA power flo air cleaner, FI2000 power pro tuner and COBRA pipes and mufflers. Im getting backfiring when I back off the throttle. I've got about 60 miles on the exhaust and wondering if I need more time to have the tuner cycle and cure the problem. Any ideas?
vincepicone is offline
post #2 of 3 (permalink) Old 08-25-2014, 08:18 PM
FDR's RGC's Avatar
Double check for exhaust leaks.
FDR's RGC is offline
post #3 of 3 (permalink) Old 08-26-2014, 02:23 AM
The newer Fi 2000 don't have the adjustment pods so there is nothing you can do. If you don't have a exhaust leak you are most likely running to lean on decel and you need to have some fuel added on decel.
The older styler Fi2000 have adjustment pods and it is easy to adjust.
You may consider taking the Fi2000 off and take the bike to HD and have the ECM reflashed than re-install the Fi2000, it may take care of your problem.
Posted in wrong section Pattywagon Dyno Results 0 04-24-2016 06:23 PM
Posted in the wrong section! Doug06rg Dyno Results 0 04-21-2016 05:26 PM
Help and sorry 4 being a pain pipe3214 ECM/Fuel Management systems 13 04-09-2015 11:39 PM
Sorry I haven't posted laxinharley General Off-Topic Discussions 11 03-16-2015 09:17 AM
Posted this on HD Forum, as to my being maybe? ddm502001 General Off-Topic Discussions 11 10-24-2013 06:56 PM
