Valve noise and oil consumption - Road Glide Forums
post #1 of 21 (permalink) Old 08-26-2014, 09:25 AM Thread Starter
Stag556's Avatar
The bike is at the dealer as we speak but I'd like to pick everyones brain here for opinions.
I noticed a noise coming from the top end of my motor a few weeks ago. It only made the noise during acceleration and not while revving the bike in neutral. I know the normal noisey valve train sounds but this sounded like an actual valve noise.
I recently took a trip to sturgis and checked all fluids which were good and at proper levels. At this point I just chalked up the noise to being the valve train and me being ovet worried because of my upcoming trip.
The noise continued all through the trip and when I returned, I checked my fluids again and my oil was barely touching the bottom of the dipstick. There are no leaks externally on the motor so I leads me to believe its internal and possibly related to this noise. Any ideas?
It a 2013 103 motor with about 9k miles. Only motor work is a SE air cleaner, vance and hines true duals with rinehart slipons and a power vision tune from fuel moto.
Stag556 is offline
post #2 of 21 (permalink) Old 08-26-2014, 11:57 AM
On the top end there is only 2 places that would contribute to oil consumption.
First is a bad crankcase breather and the oil is going into the intake and burned in the combustion chamber. There is not any visible sign of a crankcase breather problem except excessive oil in the air cleaner and throttle body.
The second is bad valve seals which allow the oil to drain directly into the combustion chambers to be burned. If the valve seals are bad you will see blue smoke on cold engine start up.
The only other thing that causes oil consumption is a piston ring problem.
As far as the top end noise you would have to pull the rocker covers and inspect the top end components.
If the repair tech at the dealer is any good he should find the problem.
post #3 of 21 (permalink) Old 08-26-2014, 12:09 PM Thread Starter
Stag556's Avatar
Thanks for the reply. Im patiently waiting for the dealer to give me a call with an update. Hopefully its something that can be rectified easily since as always, there is beautiful weather when I dont have my bike.
Im wanting to do cams over the winter so I figure its best to have all issues corrected before adding to an existing problem.
Stag556 is offline
post #4 of 21 (permalink) Old 08-26-2014, 12:15 PM
If the lifters are going bad it will sound like top end noise. If the dealer has the rocker covers off or the lifter blocks and pushrods out and this repair is covered under warranty this would be the time to do the cams because the warranty will cover part of the labor cost.
post #5 of 21 (permalink) Old 08-26-2014, 12:25 PM Thread Starter
Stag556's Avatar
Thats a good point. Ill have to give them a call to see what they have to say. They may correct the issue without even calling me if its warranty work. We shall see.
Stag556 is offline
post #6 of 21 (permalink) Old 08-26-2014, 04:20 PM Thread Starter
Stag556's Avatar
Just a quick update. The dealer said that because I use a K&N oil filter, that filter is too dense and is restricting oil pressure and flow. My air filter element is also saturated in oil. They say the lack of oil pressure is causing the noise I hear.
Seems difficult to believe that K&N would offer a filter specifically for a Harley when it was too restrictive.
Thoughts?
Stag556 is offline
post #7 of 21 (permalink) Old 08-26-2014, 05:17 PM
That sounds like bs from the dealer, I've been using k&n oil filters for years and never had a problem.
2012 FLTRX
Sideways is offline
post #8 of 21 (permalink) Old 08-26-2014, 06:32 PM Thread Starter
Stag556's Avatar
I agree. Based on their theory, people who successfully use k&n oil filters are lucky and they should cause problems.
Im no expert mechanic but I like to think im somewhat educated in mechanics. Can anyone explain how a pressure issue from the oil filter can cause excessive blowback into my air filter?
Stag556 is offline
post #9 of 21 (permalink) Old 08-26-2014, 06:38 PM
redbaron's Avatar
Thoughts?
Did they take the rocker covers off like ironmark mentioned ? I am hearing loud valve train noises from my 2012, but also not while revving it in neutral. running a K & N filter as well.
2012 Vivid Black, FM Ceramic 2-1-2 Header + 4" slash up mufflers Power Vision, PM Super Gas MERC A/C, 12" Windvest, CVO Solo Seat, XT Rokker & Hawgwire cs300 Amp, 10" Outlawz, CD Led's, Arlen Ness lowers, Ohlins S36E + progressive monotubes
redbaron is offline
post #10 of 21 (permalink) Old 08-26-2014, 07:13 PM
Boogitybob's Avatar
I'm certainly no expert but would think filter blockage would increase pressure interested in final outcome
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 06:23 AM
Excessive oil consumption Mr. E Troubleshooting for Road Glides 10 09-25-2012 08:41 PM
Excessive oil consumption? 1st Sgt Troubleshooting for Road Glides 8 08-21-2012 09:59 AM
Oil Consumption/ Compression & Brakes? TearlessTom Troubleshooting for Road Glides 18 11-06-2011 06:11 AM
Oil Consumption Crazyness road-king *General Road Glide Discussions/Pictures 9 03-31-2011 07:51 PM
