Fueling cams - Road Glide Forums
post #1 of 9 (permalink) Old 08-30-2014, 10:48 AM Thread Starter
sj01fltri's Avatar
Fueling cams
Looking for any members who are running or who have run the fueling 574 cams in a stock compression 103 with air cleaner ans 2-1 pipr.
sj01fltri is offline
post #2 of 9 (permalink) Old 08-30-2014, 11:50 AM
direwolf's Avatar
Fueling cams
I'm running them in my 107, also running Bassani Rage 2-1. 10.5 - 1 compression though
...2009 SERG...Last of the Hand Built's..
direwolf is offline
post #3 of 9 (permalink) Old 08-30-2014, 12:01 PM
Looking at the 574 specs it would seem that they would perform better in a higher compression engine, a stock 103 wouldn't have enough compression to bring out the full potential of the 574 cams. JMO
post #4 of 9 (permalink) Old 08-30-2014, 01:40 PM
Road dawg's Avatar
With the set up you have I would look into the 525 cams from feuling, I have them and on a stock motor they produce excellent torque and power, just my 2 cents.
Road dawg is online now
post #5 of 9 (permalink) Old 08-31-2014, 08:06 AM Thread Starter
sj01fltri's Avatar
I am looking at these for now,will be doing heads and higher compression later,dont want to have a extra set of cams laying around after i do the heads and pistons,since i dont have piles of extra cash sitting,i realize that i would sacrfice some low end,just starting with cams then build aroud them.
post #6 of 9 (permalink) Old 08-31-2014, 08:29 AM
Good idea. After doing just cams makes me want to do headwork as well. Defiantly more fun to ride with the added torque!
[B]PV-Big Sucker-Rush Racing H-pipe-Big Louie's-Drago's 565 cams
Nightrain04 is offline
post #7 of 9 (permalink) Old 08-31-2014, 10:15 AM
It may be best to buy the cams and just put them away until you get the high compression build done. Buy the parts as your money flow allows and when you have all the parts to do the job do all the work at once.
post #8 of 9 (permalink) Old 08-31-2014, 11:38 AM
Road dawg's Avatar
I agree with ironmark, get the cams and stash them for the build .
post #9 of 9 (permalink) Old 09-01-2014, 12:03 AM
The 574 cam works better in big bore engines with higher compression
Even then there more of a mid range cam.
But over all not a bad cam.
DragoBikeWorks is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
Fueling 525 cams, anyone got em? Road dawg Tech Area 15 10-06-2013 07:06 PM
Fueling Reaper 574 cams video BadX Engine Related 12 03-31-2012 08:26 AM
Fueling 574 cam BadX Engine Related 2 03-13-2012 05:17 PM
Fueling Up philmartin *General Road Glide Discussions/Pictures 10 03-21-2011 09:58 PM
