Engine Compression Test Question.... - Road Glide Forums
post #1 of 12 (permalink) Old 08-31-2014, 02:57 PM Thread Starter
This is a 2010 FLTRX with 51,862mi. In my mind it's time to do a compression check. The question becomes is this bike "ACR" (automatic compression relief) equipped? I don't know and I'm not sure how to find out. IF it is ACR equipped I'm supposed to remove the ACR system relay at the fuse box which might set off diagnostic trouble codes.........crap. So how do I find out?? HELP PLEASE
Nevadasun
post #2 of 12 (permalink) Old 08-31-2014, 06:35 PM
FDR's RGC's Avatar
Not equipped.96 inch never had .
FDR's RGC is offline
post #3 of 12 (permalink) Old 08-31-2014, 06:37 PM Thread Starter
Originally Posted by fdr's rgc View Post
not equipped.96 inch never had .
thanks!!
post #4 of 12 (permalink) Old 09-01-2014, 12:00 AM
2010 did not have them unless you have 103 motor or cvo.
When you do it make sure you hold open throttle blade for the right reading
We discount fuel pump by pulling fuel pump fuse also. You may get a ex heck engine code for tbw but you can clear it through speedo
Thanks
FD
Nevadasun
DragoBikeWorks is offline
post #5 of 12 (permalink) Old 09-01-2014, 12:27 AM Thread Starter
Thanks Frank, I think when you say "you can clear it through speedo" you mean take it on the highway and run it. Right?
Oh, your S/C/S 4's still look and sound great.......
post #6 of 12 (permalink) Old 09-01-2014, 11:04 AM
The DTCs will be displayed on the odometer on the speedometer, all the info on how to access and clear the DTCs are in a sticky in the troubleshooting section.
MAKE SURE TO PULL THE TCA PLUG BEFORE PERFORMING THE COMPRESSION TEST. Failure to pull the plug will cause the TCA gears to STRIP when you hold the throttle plate open, you will need a new Throttle Body to fix the strip TCA gears.
post #7 of 12 (permalink) Old 09-01-2014, 12:37 PM Thread Starter
The service manuel didn't say anything about pulling the TCA plug. However I just need to know if this is it?
post #8 of 12 (permalink) Old 09-01-2014, 08:42 PM
If my memory Serves me right you have Tmax you can clear codes there.
QUOTE=Nevadasun;2163194]Thanks Frank, I think when you say "you can clear it through speedo" you mean take it on the highway and run it. Right?
Oh, your S/C/S 4's still look and sound great.......[/QUOTE]
post #9 of 12 (permalink) Old 09-02-2014, 10:59 AM
Yes that is the plug that you need to disconnect before doing the compression test. You will get DTCs because the plug is pulled but you can clear the DTCs before riding by using the speedometer or if you have the T-Max you can use that too.
It is easy to just use the speedometer to clear the DTCs and you don't have to hook up the PC.
The reason you pull the TCA plug is because you are holding the throttle plate open and the ECM wants the throttle plate to be in the idle position. The TCA motor is trying to force the throttle plate to idle position and it can not because you are holding the throttle plate open. The plastic gears in the TCA will strip making your throttle body useless and the TCA is a non serviceable part which require a new throttle body to fix the TCA gears /motor.
post #10 of 12 (permalink) Old 09-02-2014, 11:36 AM Thread Starter
Well, I've decided not to do the compression test. I don't have a speedometer or a T-Max so, I have no way of clearing the codes. I'm sure as hell not going to take it to Harley to get the codes cleared. They say ignorance is bliss, I'll stay blissful on this one.
Going to test ride a 2018 Roda Glide what should I test. Daicaothu *General Road Glide Discussions/Pictures 55 08-16-2018 06:20 PM
Compression Test Results...Experts Chime-in Nevadasun Engine Related 4 09-03-2014 11:33 AM
Install compression releases with heads on the engine? Reddobe1 Engine Related 12 04-30-2014 10:54 AM
Compression Test BlackDangerous Engine Related 4 07-15-2013 03:39 PM
Did my own compression test on my stage IV ironmark Engine Related 22 02-12-2013 03:53 PM
