Installing new cam bearings - Road Glide Forums
post #1 of 11 (permalink) Old 09-05-2014, 02:19 PM Thread Starter
Stag556's Avatar
I am going to tackle a 107 build and one question I have pertains to the cam bearing install. I purchased the Heartland Tools installer and I am curious as to how far you install the bearing. The HD instructions say to set a torque wrench to 25 fl lbs and continue turning until that torque is met. Is this a good method to use or is there a better one?
Stag556 is offline
post #2 of 11 (permalink) Old 09-05-2014, 02:25 PM
Hullhorr's Avatar
It's been a couple years since I did mine, but I don't recall using a torque wrench at all. I just installed them until the face of the bearing was flush with the face of the engine case.
2009 FLTR MOP
Hullhorr is offline
post #3 of 11 (permalink) Old 09-05-2014, 02:32 PM
JayKS's Avatar
Yeah, same here. Fuel Moto has a series of really good installation videos. Here's the one dealing with cam installation. It deals with removing/replacing the bearings in the first few minutes of the video: https://www.youtube.com/watch?v=5IWtJW8f7xg
JayKS is online now
post #4 of 11 (permalink) Old 09-05-2014, 02:41 PM Thread Starter
Stag556's Avatar
I saw the Fuel Moto videos and watched them a few times. It doesn't specifically say how far to install them. It does mention seating them a hair past flush but I was curious if there was a definitive way to install.
I would think these installers would only have a certain amount of threads and they would end at the correct depth, therefore taking out any variables.
Stag556 is offline
post #5 of 11 (permalink) Old 09-05-2014, 03:05 PM
JayKS's Avatar
That's exactly how I installed mine, 'a hair past flush'. That seemed to work just fine.
Good luck with your build.
JayKS is online now
post #6 of 11 (permalink) Old 09-05-2014, 03:07 PM
tdkkart's Avatar
In the video above, at 4:20 you'll see him out the bearing on the installer bushing. You'll notice that the rear of the installer bushing is larger in diameter than the bearing. The step on the bushing serves as a stopping point. The installer is screwed in till it stops solidly, it cannot install the bearing too deep.
tdkkart is offline
post #7 of 11 (permalink) Old 09-05-2014, 03:07 PM
Numbers facing out as well.
HogPro is offline
post #8 of 11 (permalink) Old 09-05-2014, 08:56 PM
jack6hd's Avatar
Correct info with numbers facing out and bearing just below flush.
2015 FXDL 2nd best HD on road
jack6hd is offline
post #9 of 11 (permalink) Old 09-05-2014, 09:29 PM Thread Starter
Stag556's Avatar
Thanks for the replies guys.
Stag556 is offline
post #10 of 11 (permalink) Old 09-05-2014, 11:18 PM
The cam bearing tool that I rented was set up to install the bearing to the right depth. It was last year so I don't remember whose tool it was but I could look it up.
2012 FLTRU, BBP, SE255 cam, Fuelmoto adjustable pushrods, Arlen Ness intake, decatted head pipe, Dyno Jet Power Vision, CVO slip ons, Monotubes, Ohlin 2.5, Daymakers, Road Zepellin Seat, adjustable riders backrest, Wild 1's 518's, Street Glide rear fender, Madstad, Lots of Custom Dynamics LEDs.
Dharn55 is offline
S&S cam drive vs the new HD cam drive kit jprider4life Engine Related 4 09-04-2015 08:17 AM
Is replacing cam bearings necessary? BigNorm Engine Related 20 07-02-2015 08:40 AM
SE cam bearings? 68 EB Engine Related 3 03-30-2013 11:53 PM
Replace cam bearings with 362 miles? Eshaw301 Do-IT-Yourself 14 05-20-2012 11:40 PM
2012 FLTRU - Need new front end bearings?? Jeffdag *General Road Glide Discussions/Pictures 7 05-15-2012 03:00 PM
