2002 compensating sproket spacer - Road Glide Forums
post #1 of 2 (permalink) Old 09-07-2014, 04:09 PM Thread Starter
Hey guys,
I have a question. I am replacing the compensating sprocket assembly. The manual says there is supposed to be a spacer on the shaft btwn the sprocket and the rotor but only for low output alternators. I am also installing an 50 amp 3 phase stator and rotor. Do i need the spacer? Bike does have some performance mods.Wondering if I need th3 extra pressure on the spring. Thanks
sdphil is offline
post #2 of 2 (permalink) Old 09-07-2014, 05:04 PM
Hullhorr's Avatar
You need to be sure the sprocket on the compensator is in line with the sprocket on the clutch hub. If the new rotor is thicker than the old then you may not need the spacer.
2009 FLTR MOP
Hullhorr is offline
Tags
compensating sprocket , rotor , spacer , stator
Seal Spacer Question bbass Suspensions 0 09-28-2012 10:09 AM
Spacer Question Jetman *General Road Glide Discussions/Pictures 5 04-24-2012 10:16 PM
Torque Specs & Spacer Question Jetman *General Road Glide Discussions/Pictures 5 04-16-2012 11:12 PM
WTB Front turn signals and chrome spacer bvette94 Classifieds Archive (3 months old+) 3 04-06-2011 06:31 PM
WTB Front turn signals and chrome spacer pennstater Classifieds Archive (3 months old+) 1 03-20-2011 03:08 PM
