Fairing lower increased temps. - Road Glide Forums
post #1 of 20 (permalink) Old 09-11-2014, 10:52 PM Thread Starter
I recently put a set of vented lower fairings on my 2012 Road Glide and now I feel like my legs are catching on fire. I also noticed that my air temp intake gauge is reading near the 100 degree mark on most rides where the temp here is in the high 80's. I have the vents wide open and added a set of mid frame air deflectors with no change. The service guys tell me the bike runs about 12-15 degrees hotter with the fairing lowers and its no worry. Anyone else notice this drastic change? Wondering if I should also go to a more open air cleaner? I have a Kuryakyn Hypercharger right now.
JSCHWAG is offline
post #2 of 20 (permalink) Old 09-11-2014, 11:04 PM
I would just remove the vents. BTW, I don't want to rain on any parades, but the hypercharger is more for show than go, if you want the engine to breathe better, there are many better A/Cs.
post #3 of 20 (permalink) Old 09-11-2014, 11:26 PM Thread Starter
I thought about removing the vents also but didn't think it would give me that much more air. Will give that a try. Yeah looking for a more open air cleaner that works with lowers. Gonna get rid of the Hypercharger I think.
JSCHWAG is offline
post #4 of 20 (permalink) Old 09-11-2014, 11:47 PM
JacktheBagger's Avatar
remove the vents
may be a bit hotter with the lowers installed , but my unscientific opinion is that you are probably getting more forced air flow to the motor with the lowers than without
JtB
2011 Ultra
JacktheBagger is offline
post #5 of 20 (permalink) Old 09-11-2014, 11:48 PM
tmd
I've ridden my RGU with and without the lowers on. Personally I like the wind protection with them on. Yes it's a little bit warmer but not enough to cause discomfort or damage to the motor.
tmd is offline
post #6 of 20 (permalink) Old 09-11-2014, 11:55 PM
chromedome's Avatar
remove the vents.
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #7 of 20 (permalink) Old 09-12-2014, 08:14 AM
throttles&triggers's Avatar
Having lowers on your RG is not going to cause any heat concerns for the motor. Lowers have been on the EG Ultra for many, many years and came on the RG Ultra the three years it was produced. You may notice more heat on your legs from not getting as much airflow, but the temp difference to your engine is negligible. As others have said, you can completely remove the vents if you choose to. Depends on your riding style. For those of us who ride rain or shine and the lowers and vents provide good protection.
throttles&triggers is offline
post #8 of 20 (permalink) Old 09-12-2014, 11:18 AM
The fairing lowers won't cause the engine to run much hotter than normal but those mid frame heat deflectors are heat traps and removing them will improve air flow to the rear cylinder and let the rear cylinder run cooler.
The reason you feel the heat more is the lowers create a vacume and draw the engine heat forward before it can escape.
I usually run my hard lowers and pull the vents in the summer but this year here is AZ it was too hot (temps of 105 to 118) and I had to pull the lowers off.
post #9 of 20 (permalink) Old 09-12-2014, 10:59 PM Thread Starter
Thanx for all the great feedback guys. Pulled my vents off today so we will see how it feels at Street Vibes in two weeks. Reno will be warm!
JSCHWAG is offline
post #10 of 20 (permalink) Old 09-13-2014, 12:32 AM
skratch's Avatar
you won't notice much of a difference if you're stuck in stop and go traffic. for the vent removal to actually make a difference, you gotta be moving. (now this is all said with the caveat of never having been to street vibes, but assuming it's gonna be a crowded affair).
the lowers actually help your engine to run a little cooler by funneling air over the cylinders. unfortunately, that hot air has to go somewhere, and that is usually over your legs. i remove the vent doors every year, and put them back on for the winter. i find that the extra heat with the lowers is well worth the extra protection/wind management that you get.
skratch is online now
Increased vibration Brianu1 Engine Related 12 10-27-2014 06:05 PM
Changed Thundermax Mapping and mileage increased 1BadGlide Map Section 3 08-01-2014 08:52 AM
High Oil Pressure and High Oil Temps ironmark Troubleshooting for Road Glides 17 12-09-2012 10:44 AM
Temps, just wrong....... tdkkart ARCHIVES-SWII LeClaire, IA 1 07-21-2012 11:25 PM
