05 Motor work - Road Glide Forums
post #1 of 4 (permalink) Old 09-11-2014, 11:06 PM Thread Starter
05 Motor work
I currently have a 05 Road Glide with 88", SE Stage 1 Air cleaner, Rinehart true duals and PCIII about 48K miles. Getting ready to switch cam chain tensioner to the Screamin' Eagle Hydraulic Cam Chain Tensioner and High-Flow Oil Pump Upgrade Kit having a hard time deciding on cams and which big bore kit to install. Im considering the fueling 525 cams and having a hard time figuring out what compression to get see that they range from 9.3:1 - 10.5:1. What would be the best set up for the money.
V-style is offline
post #2 of 4 (permalink) Old 09-12-2014, 04:33 AM
If looking for torque to come quick, and carry across a large rpm band then......
Bore to 98"
Andrews 57 cams
9.8-10.0 cr
Our Stage I or II Heads
Cool running, powerful, quiet engine.
Scott
Hillsidecycle.com is offline
post #3 of 4 (permalink) Old 09-13-2014, 10:27 AM
Durwood's Avatar
Can't go wrong with that recipe
Don't forget the tune.
Durwood is offline
post #4 of 4 (permalink) Old 09-13-2014, 11:13 AM
Check out www.bigboyzheadporting.com and click on the calculators section and you can find the compression ratio for different cams and builds.
05 Road Glide motor swap V-style Road Glide Builds-Document your builds HERE --NEW 4 09-15-2014 09:41 PM
Winter Motor Work Possibly? Chicago Harley Boy *General Road Glide Discussions/Pictures 7 07-21-2013 10:27 PM
Lower Fairing doors - 58681-05 & 58679-05 akawolf Sold 1 03-10-2013 12:25 PM
Will a Dyna Oil Cooler adapter #26111-05 work on a RG that calls for adapter # 26151- Trikerjon *General Road Glide Discussions/Pictures 1 10-14-2010 08:40 AM
'05 Road Glide, from Raleigh SkootchNC *General Road Glide Discussions/Pictures 4 11-24-2009 03:42 AM
