57H cams - Road Glide Forums
post #1 of 7 (permalink) Old 09-17-2014, 11:04 AM Thread Starter
Darreldanger's Avatar
57H cams
Hey guys with the Andrew 57H how much hotter does your engine run with all that lift.
Darreldanger is offline
post #2 of 7 (permalink) Old 09-17-2014, 01:09 PM
ERod62's Avatar
Don't have oil temp gage but stock on heavy traffic for long periods of time, run few parades and down Main Street Daytona bike week no over heating issues at all. Two in the group got over heated, on Main St Daytona, both run reg oil. Don't want to start an oil dispute but running synthetic makes a difference.
Running this cam on stock engine very please with the results. Over 15k ml since installed last spring.
ERod62 is offline
post #3 of 7 (permalink) Old 09-17-2014, 02:31 PM
Durwood's Avatar
Lift doesn't create heat, 57h is a real good bolt in cam for a 103, pick the right exhaust and get a good tune.
Don't forget the tune.
Durwood is offline
post #4 of 7 (permalink) Old 09-18-2014, 06:59 AM
No heat should be increased by the use of that, if anything reduced.
Scott
Hillsidecycle.com is offline
post #5 of 7 (permalink) Old 09-18-2014, 07:59 AM
That's the cam I chose after reading a lot of cam related threads. I'm using a .030" HG and a 2-1 pipe with a good tune of course.
Berms is offline
post #6 of 7 (permalink) Old 09-18-2014, 09:25 AM
Durwood's Avatar
Cool, Is your dyno sheet on here?
Durwood is offline
post #7 of 7 (permalink) Old 09-28-2014, 08:14 AM
I have the cams and HG but haven't got the bike yet!
I will be sure to post results when all together and tuned on the dyno
Berms is offline
2013 RG PV Map needed for 57H Cams Deadstroke Map Section 18 05-23-2016 09:57 PM
Andrews 57H Cams-What pipes are you running? LM1976 Intake and Exhaust 7 05-11-2014 07:00 PM
New Cams Adrews 57H mechanicalman *General Road Glide Discussions/Pictures 0 03-26-2014 03:02 PM
PV map for 106/107 kit, 57H cams and heads mffi497 Map Section 1 11-25-2013 10:00 AM
Andrews 57H cams ShitHouseRat Sold 6 09-11-2013 08:33 PM
