Fix it or 2015? FIX! - Road Glide Forums
post #1 of 25 (permalink) Old 09-20-2014, 04:55 PM Thread Starter
08Zinc's Avatar
Last winter's project(s) included the Stage 4 103 kit for my '11 FLTRU. After the Meet up at State College, I realized that something was wrong and the bike was way low on oil. Dealer replaced the umbrella valve in the new SE heads and said all was well. It wasn't. Pinging ensued and I took it back twice for retuning. This was an awesome bike to ride after the Stage 4 kit and I loved it. However, I have been a very unhappy Glider since April with the continued issues.
More time goes by, and more pinging, and more black soot out of the left pipe. And yes, I noticed that it was spitting oil out of the pipe again and once again was low on oil. While at DelMarrVa Bike Week, Speed's Performance had two people suggest that the real issue was the Valve Guide seal. So - call the dealer and have them look at it.
Took my bike in today and the GM offered me a test ride on a 2015 Road Glide Special - Horrible wind management. (But love the new handle bar bend) So, I really hope they can get my bike fixed properly.
Anyone else have this issue with it spewing oil out the rear pipe and pinging? It never pinged before the fix of the umbrella valve.
Blessings, Zinc -
08Zinc is offline
post #2 of 25 (permalink) Old 09-20-2014, 08:26 PM
Hullhorr's Avatar
It does sound like a valve seal problem. The new 15's are always an option, but if your like me I have way too much invested getting mine the way I like it to start over again.
2009 FLTR MOP
Hullhorr is offline
post #3 of 25 (permalink) Old 09-20-2014, 08:30 PM
pipe3214's Avatar
I want a stage 4 kit on mine. How's the performance after it was installed without the issue would you be happy with it??
pipe3214 is offline
post #4 of 25 (permalink) Old 09-20-2014, 10:42 PM Thread Starter
08Zinc's Avatar
Yep, I'm like you and have too much in my '11 to think about the '15, though I test rode a Special today while taking the bike back. Prefer my 11.
Not really sure that the issue has anything to do with the Stage 4 kit. I would do it again in a heartbeat.Glad it kept the bike under warranty.
Blessings, Zinc -
08Zinc is offline
post #5 of 25 (permalink) Old 09-21-2014, 12:53 AM
pipe3214's Avatar
08 zinc. Do you have a stage 4?? How's it run and do you like it
pipe3214 is offline
post #6 of 25 (permalink) Old 09-21-2014, 10:27 AM
IMO a stage IV is a waste of good money been there done that got my 103 stage II back in the engine and all is good.
If your valve seals are bad you will see a cloud of blue smoke when you start the bike in the morning or after the bike been sitting for a while. This happens because the oil in heads has time to leak pass the valve seals and collect in the combustion chamber. If you don't see the blue smoke on first start up than the valve seals are good.
If the umbrella valve is bad you will have a lot of oil in the air fliter and throttle body and oil will be on the cam cover no matter what you oil level is or how hard you run the bike.
My stage IV used oil too and I suspected that it was blowing by the rings.
post #7 of 25 (permalink) Old 09-21-2014, 04:42 PM Thread Starter
08Zinc's Avatar
That backs up what I heard from a non-dealer wrench. Thanks!
Blessings, Zinc -
08Zinc is offline
post #8 of 25 (permalink) Old 09-22-2014, 07:11 AM
Sounds like poor engine building and a poor tune.
Scott
Hillsidecycle.com is offline
post #9 of 25 (permalink) Old 09-22-2014, 01:27 PM
I dont ping, but the valve train is noisy.
I would have built a different engine knowing what i know now.
I've got 18K miles on the stage IV and i dont consume oil anymore. The first few thousand miles i had oil consumption.
My left exhaust is always sooty. I have the V&H with the x pipe, the right exhaust comes out with way more velocity so I dont think it deposits on that side as much.
2011 RG Custom, Screaming Eagle Stage IV (260 Cam), Barnett Scorpion clutch, Hayden M6, Baker DD7, V&H Throttlepak, V&H Power Duals w/Hi-Output Slipons
115.4 ft-lb & 122.7hp : 1/4 Mile 12.542 @ 105.99 w/stock clutch and transmission
gbourdon is offline
post #10 of 25 (permalink) Old 09-22-2014, 04:04 PM
pipe3214's Avatar
How's the power of your build. What would you a built different from a stage 4
pipe3214 is offline
Tags
103 , pinging , stage 4 , valve guide seal
How To Fix TBW Issues After Internal Wiring Donk Controls & Handlebars 164 07-12-2018 02:11 PM
2015 Whistling Faring Fix (50-60 mph) MotoPGG Troubleshooting for Road Glides 1 07-19-2015 07:26 PM
Fix For Buffeting? BadPiggy *General Road Glide Discussions/Pictures 11 02-27-2011 02:01 PM
FIx For Stock Seat added heat ROADEAGLE Seating: seats, backrests 1 01-09-2011 07:50 PM
Frame Wobble - whats the fix? Sincecrazy Troubleshooting for Road Glides 2 08-27-2010 10:22 AM
