Cams - Road Glide Forums
post #1 of 10 (permalink) Old 09-21-2014, 10:14 PM Thread Starter
pipe3214's Avatar
Cams
How hard is it to install cams?? My dealer wants $500 to install them. I've built stock car motors and just never worked on a Harley. Are they simple or what. Can I get some advise please :-).
pipe3214 is offline
post #2 of 10 (permalink) Old 09-21-2014, 10:26 PM
pat123's Avatar
They are one of the easiest engines I have ever worked on. Simple tools,torque wrench and a workshop manual is all you need.
pat123 is offline
post #3 of 10 (permalink) Old 09-21-2014, 10:32 PM Thread Starter
pipe3214's Avatar
Sweet. Any idea how long it takes??
pipe3214 is offline
post #4 of 10 (permalink) Old 09-21-2014, 10:36 PM
pat123's Avatar
2 to 3 hours at the most. Really depends which way you do it and what pushrods you use. Use chain cutters to cut the old pushrods and SE adjustable pushrods and you can have it done in less than a hour and half.
pat123 is offline
post #5 of 10 (permalink) Old 09-21-2014, 10:38 PM Thread Starter
pipe3214's Avatar
Thank you. :-)
pipe3214 is offline
post #6 of 10 (permalink) Old 09-21-2014, 11:48 PM
kouack's Avatar
You will want to replace the pos cams bearings so you will need a bearing puller and installer ;-)
kouack is offline
post #7 of 10 (permalink) Old 09-21-2014, 11:53 PM Thread Starter
pipe3214's Avatar
Where would I get new bearings and are they gonna be roller ??
pipe3214 is offline
post #8 of 10 (permalink) Old 09-22-2014, 01:10 AM
torqu's Avatar
I'm pretty sure they are Torrington B - 168.
torqu is offline
post #9 of 10 (permalink) Old 09-22-2014, 07:15 AM
May want to consider a good set of lifters as well, particularly if you have "C" lifters.
Scott
Hillsidecycle.com is offline
post #10 of 10 (permalink) Old 09-22-2014, 08:45 AM
mocotom's Avatar
Scott
Take Scott's advice and replace the lifters when you do the cam swap, or you will end up tearing it apart the second time in a couple thousand miles.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
Gear Drive Cams??? sportyguy69 Engine Related 17 11-16-2010 04:46 PM
551 vs 585 cams watty Engine Related 4 11-16-2010 03:29 PM
Woods TW6H CAMS OR SE251 IN 95CI tr17047 Engine Related 2 06-23-2010 12:02 PM
