Power vision question - Road Glide Forums
post #1 of 3 (permalink) Old 09-23-2014, 09:59 AM Thread Starter
I hv 2012 fltrx,cams etc I'm getting a little pinging around 2600 to 2900 when I roll on the throttle, most noticeable in 4th and 5th gear. Should I just go into QuickTune to spark table and retard spark in medium range? Suggestions welcome. Thanks
jj8823 is offline
post #2 of 3 (permalink) Old 09-23-2014, 11:29 AM
PGR
PGR's Avatar
Go to the powervision website....... download the tune that matches your setup the closest http://www.dynojet.com/powervision/P...Downloads.aspx ....install the tune ......... run several autotune sessions. That should fix you up.
Ron..........................
PGR is offline
post #3 of 3 (permalink) Old 09-23-2014, 03:27 PM
mocotom's Avatar
The quick tune is a great feature but if you are only experiencing pinging in a specific area like you describe, I would remove a couple degrees of timing at that particular problem area . Quick tune will reduce timing over a large RPM - Kpa area and is normally used in a broad pinging situation such as caused by poor fuel quality.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 03:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 01:29 AM
Power Vision When not on the bike Question.. RhinoHD ECM/Fuel Management systems 6 12-19-2012 10:36 PM
power vision question vtglide ECM/Fuel Management systems 2 05-26-2012 09:15 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 08:21 AM
