255 vs 204 in a 103 - Road Glide Forums
post #1 of 10 (permalink) Old 09-25-2014, 03:58 PM Thread Starter
Glidr's Avatar
255 vs 204 in a 103
I tried to search for some info on this but didn't have much luck so any input will be helpful.
I have a '13 Custom with a Heavy Breather, Fullsac Sport Pipe, 4' Rineharts, & TTS Mastertune.
I tend to like the 0-whatever's pretty fast and cruise around 75-80 with the occasional runs into higher numbers. I like low end torque and mid range punch for passing and climbing in hills without downshifting if I can avoid it and split my riding time about 50/50 solo & 2up. My wife only weighs 100 lbs so she doesn't add much to the equation weight wise.
My plan is to swap cams and get a tune from Doc.
I can get 255 with about 1500 miles for cheap from a friend or buy 204 new...
Can anybody offer up any info on the contrast in these two and benefit of a 255 aside from it costing about $250 less because it's used.
Thanks
'13 RGC Vivid Black, Windvest, HID upgrades, 14" Buky Assaults with chromed top end, Heavy Breather, Fullsac Sportpipe, Rinehart 4", SE 255, TTS Mastertune, PM Launch 21/17 Xquisite cut, a few other chrome pieces and a list of plans like the rest of us.
Glidr is offline
post #2 of 10 (permalink) Old 09-26-2014, 09:47 AM
The HD cams are EPA compliant so they are a good cam to stay away from if you want a good cam go with a aftermarket cam.
I have the Woods 222 and I love them but Andrews, T-Man among other manufactures make good cams too.
post #3 of 10 (permalink) Old 09-27-2014, 01:24 AM
^^^^^what he said. I like my 255's but I got them for free. They give a good tourqe increase over stock, but there are better cams for the money.
2012 FLTRX
Sideways is offline
post #4 of 10 (permalink) Old 09-27-2014, 12:06 PM
Desertwndrr's Avatar
If you are getting it cheap, then the 255 cams are a great upgrade. That's what I have in the wife's Softail because I got them for free. If you are spending money on cams, then I'd go with Andrews 48's personally.
I know that Doc is fond of the 255 cams.
Whichever cam you want to use, get comfortable with your decision prior to getting the tune. It really gets expensive dyno tuning cam after cam.
Desertwndrr is offline
post #5 of 10 (permalink) Old 09-29-2014, 03:19 PM
FLtroll's Avatar
I'm running the 255's because I got them for little of nothing and the dealer won't give me crap on warranty work. However, I really do like them. I do not ride in the upper band, and these have right off idle torque for 2 up riding. Don't have to rev it up and feather the clutch to get rolling when loaded, and I still get 46 mpg 2 up and loaded down with luggage.
2011 Road Glide Ultra. Merlot Sunglo
FLtroll is offline
post #6 of 10 (permalink) Old 09-29-2014, 08:09 PM
Easyryder01's Avatar
Interested in this as well.....I just installed 255 after removing 254 cams and I think the for 254 were better but I'm looking for some more snap or torque that I would get with the 254 but I want it earlier not later.
2017 RGS Velocity Red
Easyryder01 is offline
post #7 of 10 (permalink) Old 09-29-2014, 08:41 PM
Banned
I had the SE204 cams in a 2012 wide glide. It dyno'd around 91-92hp and around 100 ftlbs torque. It hit right out the gate from about 1000rpms to 3500rpms then fell off from the there. Basically the 255 is a good cam for touring if your already at a cruising speed and get on it... Say to pass !
The 204 was great from a dead stop and getting on it... It would give you everything right out of the gate then fall off but still will pick up more HP and TQ everywhere compare to stock cam
Scootin is offline
post #8 of 10 (permalink) Old 09-29-2014, 08:59 PM
ERod62's Avatar
255 vs 204 in a 103
I will go to aftermarket but since Doc is tuning the bike he will guide you right, ask him for recommendations.
Am running Andrew 57H tuned by Doc . Very please.
ERod62 is offline
post #9 of 10 (permalink) Old 10-08-2014, 09:17 PM
Road dawg's Avatar
+1 aftermarket all the way. much better choices out there.
Road dawg is online now
post #10 of 10 (permalink) Old 10-10-2014, 02:43 PM Thread Starter
Glidr's Avatar
Well I went with the 255 because they were CVO take-offs and I got a really good deal on them. Put them in and downloaded a base tune from TTS. I put 100 or so miles on them yesterday to get a feel for them and so far I like them. I'll put in some seat time this weekend and have a better idea.
Do any of you guys have any experience with a canned tune VS something Doc has tuned. I know I will get a tune specific to my bike with him on the dyno, as opposed to a blanket approach. I'm just wondering how much different the two might be.
Thanks
Glidr is offline
Need a pcv map 103 with se 204 cam waffler ECM/Fuel Management systems 0 04-30-2016 01:07 PM
13 road glide 103 with 255 cams schlum13 Dyno Results 14 07-12-2015 08:26 PM
CVO 255 cams (AKA SE-255) cams pat123 Parts for Sale 3 07-26-2013 09:58 AM
07 103" Roadglide, Stock Heads, 255's hdxbones Dyno Results 24 10-13-2012 02:10 PM
Factory 103 vs Dealer-installed 103? HD_Shock Road Glide Specific Discussions 18 10-11-2010 03:06 PM
