Blue Smoke? - Road Glide Forums
post #1 of 5 (permalink) Old 09-28-2014, 07:48 PM Thread Starter
PAVEMENTPILOT's Avatar
Blue Smoke?
So, beautiful fall day for a ride here in New England. Sunny, in the 80's, leaves starting to show some beautiful colors. After a couple hundred miles, while descending a large hill, my son in law tells me he see's blue smoke puff out of my right side exhaust pipe. This has me a little concerned. Bike ('13 ultra) has run excellent, never beat on, just under 7K on the clock. Oil level good, no oily soot in tailpipe. Plugs also look good. Just a fluke or the beginning of a potential problem. Still got a few months left on warranty. What else might I lean towards, or just don't give it a 2nd thought.
PAVEMENTPILOT is offline
post #2 of 5 (permalink) Old 09-28-2014, 08:25 PM
FrankieB's Avatar
Could have been an oil bugger going down the intake if your head breathers are routed to the backing plate.
06 RK
11 RGU
FrankieB is offline
post #3 of 5 (permalink) Old 09-28-2014, 08:46 PM
gazrnr's Avatar
Mine is starting to do that too according those that follow me. I'm at 18,000 miles. Tried an oil/filter change even though I do both at 3500 miles and Amsoil 20/50 & HD filters but it still smokes when hot.
2009 Road Glide, Fueling 525 Cams, Rinhart Mufflers, SE Air Cleaner, PCV & Autotune, Progressive monotube cartridges, Ohlins shocks
gazrnr is offline
post #4 of 5 (permalink) Old 09-28-2014, 10:31 PM
mocotom's Avatar
The problem you are describing is usually associated with leaking valve seals. When descending a hill your throttle is closed for an extended period of time with engine RPM's usually at or above 2500. This causes a very high vacuum in the engine and will pull oil around the valve seals and into the combustion chamber.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 5 (permalink) Old 09-29-2014, 07:00 AM
Smoke on deccel indicates seals/guides, and smoke on acceleration usually points the finger at rings/bore.
Scott
Hillsidecycle.com is offline
My Blue got mo Blue jclax01 *General Road Glide Discussions/Pictures 27 04-02-2018 10:51 PM
WTB: Tour pack match for blue/dark blue 2012 CVO RG Jbbrown73 Wanted! (Buy or Trade) 0 02-12-2015 10:29 PM
Bellowing Blue Smoke Ezgoin721 *General Road Glide Discussions/Pictures 13 03-13-2012 11:11 AM
windvest 14 smoke dgoodbmw Windshields 23 06-21-2010 11:43 AM
