Installing cams and changing head gasket question - Road Glide Forums
post #1 of 11 (permalink) Old 09-30-2014, 07:45 AM Thread Starter
When doing a cam install with adjustable pushrods, how many additional hours labor would an average Indy need to change out the HG as well?
I'm planning on doing the above, but not if it's going to cost too much. I'm definitely not able to afford any head work, so it's just a head gasket swap from factory to a .030" for a bump in compression to help the cam.
Thanks for any advice.
Berms is offline
post #2 of 11 (permalink) Old 09-30-2014, 09:21 AM
Why go with adjustables if you are going to pull the head? If you need to pull the pushrods at a later date, you can use bolt cutters & cut them then. Also be sure to get a MLS type gasket instead of the graphite style. As for hours I am not sure how much a Indy would charge, but if I remember correctly it Took me about 4 hrs on the head gaskets.
Toby
twistedcherokee is offline
post #3 of 11 (permalink) Old 09-30-2014, 09:34 AM
Denim Glide11's Avatar
If a shop is doing it there is a huge increase in labor, if I remeber correctly book time is like 6-8 hrs just to pull rocker boxes and change cams. Almost double of what it takes to change cams with adjustable push rods.
The bump in compression is hardly worth it, what cams are you thinking about, what bike , what year, what engine?
A lot of factors go into choosing the right cam but we need some more info.
2011 FLTRX 103
TTS Mastertune,Ness Big Sucker
Avon Air cushioned grips
10" Windvest smoked shield
Bitchin Baggers heel shift eliminator
Denim Glide11 is offline
post #4 of 11 (permalink) Old 09-30-2014, 09:52 AM
If doing a head gasket don't bother with adjustable push rods as they will not be needed. If the heads are off you can reuse stock assuming they work with your cams and they will be accessible. I'd say adjustables and no head gaskets or non adjsutbles and do a head gasket.
Drew
HogPro is offline
post #5 of 11 (permalink) Old 09-30-2014, 11:58 AM
Going from the stock .045 head gasket to the .030 head gasket won't bump the compression up that much but if you want a bit more compression than go for it.
Look up Big Boyz heads and go to the calculator section and you will see how much compression gain you will get.
The heads are a easy DIY and there is no need to have a shop do the work if you have basic hand tools a 3/8 torque wrench and some mechanical ability along with a HD service manual.
I can tear the heads off and put them back on and be riding the bike in 3 to 4 hours.
Personally I would just leave the heads alone but you can just pop off the rocker covers and rockers and pull the stock pushrods and reuse the stock pushrods if you want to save a few bucks.
post #6 of 11 (permalink) Old 09-30-2014, 08:07 PM Thread Starter
Thanks for the info.... Can't afford double the labor just to swap out HG. Looks like I'll be just bolting in the cams.
Bike is a '15 RGS stock 103" . Cams are the 57h cams.
Berms is offline
post #7 of 11 (permalink) Old 09-30-2014, 08:28 PM
You should still check out www.bigboyzheadporting.com and go to the calculator section.
You will find the calculator on the cams which will tell you what the cam will produce in HP, torque and compression.
Compare the Andrews 57H with other cams such as the Woods 222 or 555 or the T-man 555.
post #8 of 11 (permalink) Old 09-30-2014, 08:31 PM
Some people are giving bad advise about not using adjustable push rods. You have to take in account that if you use a thinner head gasket you will lower the height of your heads so you would need custom length push rods also not all Cams are ground on the same base circle as Stock so that would also change the required lenght for proper rocker adjustment.
So could you use Stock push rods? Yes, BUT you will have to do some homework to make sure everything will work. Adjustables are easier
Jims79FLH is offline
post #9 of 11 (permalink) Old 09-30-2014, 08:35 PM
That is a cool link. Thanks!
post #10 of 11 (permalink) Old 10-01-2014, 08:27 PM Thread Starter
Thanks for all the advice. I cant afford the labor to swap out the HG, so I'm going to look for a "bolt in" cam and leave the heads alone.
Berms is offline
cams,cams,cams dozer23 Engine Related 2 03-03-2017 09:18 AM
2016 RG tman 600sm cams/.030 head gasket 2016RGproject Dyno Results 10 02-16-2016 09:43 AM
'12 FLTRX - Dragos 1.5 heads, 580 cams, Dragula 2, .040 head gasket modot66 Dyno Results 8 08-21-2015 09:56 PM
Thinking about changing cams, Lifters and Pushrods Straitline Engine Related 14 07-01-2014 08:13 AM
Changing Head Pipe Question Willy_B Intake and Exhaust 17 08-14-2012 10:40 AM
