Dragos 124 engine/S&S 124 - Road Glide Forums
post #1 of 42 (permalink) Old 10-06-2014, 02:13 PM Thread Starter
JKRSDETROIT's Avatar
Has anyone put this engine in their roadglide and if so opinions? Going to do a 124 this winter, just not sure if Iam going S&S or Dragos.
JKRSDETROIT is offline
post #2 of 42 (permalink) Old 10-06-2014, 02:57 PM
Q-Hog's Avatar
Subscribed..
Q-Hog is offline
post #3 of 42 (permalink) Old 10-06-2014, 05:33 PM
ITOLDU's Avatar
Several on here have done it, Mitchdom, Piesek and myself to name a few.
I have NO complaints. Mine was built with 10.2 compression and the S&S 585 eazy start cam. There are other options more compression and different cams. I went this route for the most reliability I could get and my builders recommendation. Power comes on early and it is a STUMP puller which is what you want in these heavy monsters. Good luck either way you go!
ITOLDU is offline
post #4 of 42 (permalink) Old 10-06-2014, 09:43 PM
Either way you go you will be happy!
Both come with a 1 year warrnty!
Also with us we offer package deals with our 124" motors. Tuners and pipes clutch and our injectors and our IDS & std chain drives.
We have maps for
POWER VISION
TTS MASTERTUNE
THUNDERMAX
And can provide any of the efi tuners above in package deals
If you have any questions please call 815-765-1790 ask for Frank
Thanks
FD
DragoBikeWorks is offline
post #5 of 42 (permalink) Old 10-07-2014, 11:47 AM Thread Starter
Frank I already have your Dragula pipe and Thudermax. Right now Iam running a 107 with Tman porting, 660 cams, roller rockers, 58mm HPI worked throttle body, 5.3 gram injectors. I believe I can use the Thundermax and throttle body on either set up correct? Could also use the dragula but go with the bigger baffle correct? Will call ya Frank. In the brainstorming, info gathering stage. lol
post #6 of 42 (permalink) Old 10-07-2014, 11:53 AM
Yes you can use Tmax
yes we have a map for our 124 inch with dragula and 3" baffle
No problem just give me a call
Thanks FD
post #7 of 42 (permalink) Old 10-07-2014, 12:13 PM
I have the S&S crate. 640 cams, 10.8 to 1, 66mm throttle hog, 140hp, 137tq
Runs like a raped ape, crotch rockets don't even know what to do when your next to them. It's loud and nasty
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #8 of 42 (permalink) Old 10-11-2014, 01:04 AM Thread Starter
Ok looks like the Dragos 124 crate for me. Will keep everyone posted when the trigger is pulled.
post #9 of 42 (permalink) Old 10-11-2014, 04:01 AM
Kevin0032's Avatar
Yes. Keep posting. Thinking if doing the samw
Thanks,
Kevin
2013 Road Glide Custom
Kevin0032 is offline
post #10 of 42 (permalink) Old 10-11-2014, 10:39 AM
Q-Hog's Avatar
I'll interesting. Good luck.
Q-Hog is offline
Dragos 124 touring engine crate motor DragoBikeWorks Dyno Results 11 07-07-2015 10:56 PM
124 s&s / 120r to 124 Vinny Engine Related 80 05-18-2015 12:58 AM
star racing s&s 124 engine wildchild Engine Related 22 12-26-2013 08:13 AM
Dragos new 124 blower motor 6lbs boost only DragoBikeWorks Dyno Results 8 08-05-2013 10:37 AM
