2011 RGU Engine Upgrade Input wanted - Road Glide Forums
post #1 of 6 (permalink) Old 10-06-2014, 04:54 PM Thread Starter
I am new to the HD scene and wanted to do a little to my RGU, basically I wanted to get a little more power and get rid of the exhaust heat.
I am considering the following parts:
True Duals Headpipe to reduce the heat (no manufacturer selected yet)
Fuel Moto FM Pro Billet air cleaner
Tuner Power Vision
Cams (not sure of brand)
CFR Slip On's (Already have)
Overall goal is to have more power in the mid and upper ranges.
Does anyone have any experience with true duals/cams that fit the above criteria?
Thanks
oc357 is offline
post #2 of 6 (permalink) Old 10-06-2014, 09:27 PM
If you look in the Dyno section you can see many combos of cams and pipes with Dyno sheets.
thanks
FD
Tuner Power Vision
Thanks
DragoBikeWorks is offline
post #3 of 6 (permalink) Old 10-07-2014, 02:53 AM
Taccone's Avatar
OC357, you had one of the most knowledgeable Harley performance builders comment on your post, I'll just say this, Contact frank at Drago's and have him put together a kit. He's highly recommended here! His knowledge wont steer you wrong my friend!
Taccone is offline
post #4 of 6 (permalink) Old 10-07-2014, 07:18 AM
Tuner Power Vision
Thanks
Rhinehart True-Duals comes to my mind.
Contact Eastern Performance for the best price on those.
Scott
Hillsidecycle.com is offline
post #5 of 6 (permalink) Old 10-22-2014, 03:04 PM
Durwood's Avatar
Tuner Power Vision
Thanks
Good choice of tuning device, personally, I would not run true duals, a GOOD tune will get rid of the heat.
I would run an X pipe, from fuel moto, Full sac, V&H, ect. OR a 2-1.
Then add a set of Andrews 57's for cams and you will be a happy man.
I just did another one of these last week, and for a "Bolt in" Stage 2 build it's hard to beat.
Power feels good everywhere.
Good luck.
Don't forget the tune.
Durwood is offline
post #6 of 6 (permalink) Old 10-23-2014, 07:02 AM
If looking for even more in the low-mid, an Andrews 48 REALLY pumps up that area.
Scott
Engine Builders... need some input on cams Spazz Engine Related 11 06-19-2016 08:52 AM
High Compression Pistons for the HD 110 Upgrade kit - input oc357 Engine Related 2 06-17-2016 07:05 AM
Dealer wanted 15k for 2011 RGU trade in vizcarmb *General Road Glide Discussions/Pictures 32 05-24-2013 11:58 AM
Wanted stock 2011 or 2012 exhaust head pipe for RGU boomerman Classifieds Archive (3 months old+) 6 08-15-2011 09:26 AM
2011 RGU Engine "clank" sound... help!! roadog28 Troubleshooting for Road Glides 8 07-01-2011 10:19 PM
