What cam? - Road Glide Forums
post #1 of 3 (permalink) Old 10-12-2014, 07:55 PM Thread Starter
RootBeerFXS's Avatar
What cam?
Ok, this my first FI moto and I have a tuning question. I have a 13 RG. D&D Fat Cat, Heavy Breather, unknown cam and don't know if it was tuned. Got it used from the dealer with 11k miles. Dealer thinks it's 255s, but is there a way to tell without removing them?ha
1985 ExciteBike Champion
RootBeerFXS is offline
post #2 of 3 (permalink) Old 10-12-2014, 08:07 PM
ERod62's Avatar
Get a dyno run depend on numbers you get should know if other than stock cam. To know which one have to open it up.
Typical cam power upper 90's hp and 110 tq or close. On after market cam. Look around dyno post for 255 average power.
Good luck
ERod62 is offline
post #3 of 3 (permalink) Old 10-13-2014, 12:47 AM
Desertwndrr's Avatar
If you have an exhaust and breather and its not tuned, it'd be running pretty poorly and hot as hell. It should have had a tuner with it. Might be able to check that for the specs. If not, about the only thing that I can think of is to pull the cams and visually check them. First try popping off the pushrod retainer and lifting the pushrod covers to see if adjustables are in there. Likelihood is that if cams were done then you would have adjustables, not 100%, but most dealers would install them for the time savings. No adjustables and more often than not you won't have new cams.
Desertwndrr is offline
110 best cam using SE cam Yellow09SERG Engine Related 10 12-07-2015 12:53 PM
To Cam or Not To Cam is the Question? Cmathias Engine Related 29 07-11-2013 01:25 PM
Twin-Cam Cam Chain System problems Phantom6722 Engine Related 14 11-16-2012 07:56 PM
TC88 Cam/Cam tensioner advice zglide2003 Engine Related 2 08-31-2012 12:01 PM
Anyone beat,1999 twin cam 90000 miles still got original cam tensioners Bigtrev8xl *General Road Glide Discussions/Pictures 11 04-22-2012 01:29 AM
