When do you need stronger clutch? - Road Glide Forums
post #1 of 17 (permalink) Old 10-19-2014, 07:51 AM Thread Starter
When should you go with a stronger clutch setup than stock? My 09 103 has Wood 222 Cams, Fuel Moto 2-1-2 exhaust and Power Vision using maps designed by Jamie at Fuel Moto. Going by FMs dyno's with same setup I should be getting about 95 hp and 112 torque.
Fuel Moto header (no cat) Jackpot 2 1/2 mufflers, PV by Fuel Moto, BAL1, Woods 222 cam
baldwookie is offline
post #2 of 17 (permalink) Old 10-19-2014, 08:11 AM
Banned
when your driving thru the one you have
PF120 is offline
post #3 of 17 (permalink) Old 10-19-2014, 08:53 AM
JacktheBagger's Avatar
the stock setup should be good up to around 100 HP maybe a tad more
course depends on you as well
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 17 (permalink) Old 10-19-2014, 08:53 AM
Triplej's Avatar
I have the same setup as you and the clutch started slipping as soon soon as I installed the 222 cams.
Triplej is offline
post #5 of 17 (permalink) Old 10-19-2014, 09:27 AM
Hullhorr's Avatar
If your clutch isn't slipping I wouldn't bother with it. Your next step would probably be a VPC addition to your stock setup if you are experiencing any slipping or the SE spring.
2009 FLTR MOP
Hullhorr is offline
post #6 of 17 (permalink) Old 10-19-2014, 10:32 AM
The stock clutch plates works just fine for your bike.
A stronger clutch spring is what you would need.
I use the HD SE clutch spring in my clutch with no problems, if your bike doesn't already have it you should put one in.
The SE Clutch spring doesn't cost much and it is a easy DIY.
post #7 of 17 (permalink) Old 10-19-2014, 11:37 AM
Desertwndrr's Avatar
I blew through my stock clutch with headwork and mild cams. Even the Screaming Eagle spring wouldn't fully hold. Bike dynoed at 101hp/118tq. Bought a Bandit Sportsman and I now have no issues. I've been able to set it up with a lighter pull than stock and it holds solid.
Desertwndrr is offline
post #8 of 17 (permalink) Old 10-19-2014, 01:51 PM
connector's Avatar
Stock with the AIM VPC lasted for a couple years but this summer it started to go, so i put a Energy 1 in. Wouldnt worry about changing till its a problem.
09 FLTR 103 Stage III
connector is offline
post #9 of 17 (permalink) Old 10-19-2014, 05:05 PM
ChivoChavez321's Avatar
Dropping off my bike tomorrow (Monday) for the 107 kit at FM. Will see what they recommend in regards to clutch. You wouldn't happen to be dropping yours off on Monday also?
2013 Big Blue Pearl Road Glide Ultra. Monster Ovals, Jackpot Ceramic Headers, Fuel Moto Power Vision and Billet Air Cleaner, Oil Temp guage, saddle bag bumpers, 11.5" rear progressives 444, monotubes -1, Woods TW-777 cam 107 FM kit with Level B Heads, polished throttle body. 123 Torque/113HP. "Lord, help me to be half the man my dog thinks I am"
ChivoChavez321 is offline
post #10 of 17 (permalink) Old 10-19-2014, 09:59 PM Thread Starter
Chivo- Thanks for checking with them! No, I put all their stuff on myself and love it! When I win the big lottery I will be coming for a big motor build tho!
What do you do to make a living ? slaterman5 General Off-Topic Discussions 1476 11-12-2019 09:51 AM
What do you lubricate your clutch cable with? Road dawg Controls & Handlebars 6 03-23-2015 12:03 AM
What do u do when you drive up in back of a group of BANDITOS? BillyBob *General Road Glide Discussions/Pictures 63 02-13-2011 01:23 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 02:53 AM
