SE Plug Wires Suck ?? - Road Glide Forums
 5Likes
post #1 of 19 (permalink) Old 10-25-2014, 07:08 PM Thread Starter
Gary R's Avatar
I just put red SE plug wires on my '15 RGS. Now my mech tells me they're known for screwing up the ion sensing knock retard algorithm in the ECM. Ain't researched much yet but it certainly appears to be substantiated several times. Doubt it, but maybe I'll get a refund.
Gary R is offline
post #2 of 19 (permalink) Old 10-25-2014, 07:24 PM
Bullshit!!! The SE wires won't hurt a thing. I run SE wires for years and never had a problem.
The SE wires and stock wires have the same amount of resistance. Take a multimeter and check the resistance both the SE wires and stock wires should read around 5.3 to 5.8 OHMS of resistance.
As long as the bike runs fine don't worry about it.
post #3 of 19 (permalink) Old 10-25-2014, 08:36 PM
I put the SE plug wires on about a year ago and I haven't had any problems
post #4 of 19 (permalink) Old 10-25-2014, 09:21 PM Thread Starter
Gary R's Avatar
Yeah, mine seems to run fine and not convince yet that it's a problem. In fact I posted hoping someone would throw up the bullshit flag.
I guess radical impedance differences could effect detonation time detection, but I'm still not believing it.
I keep y'all updated with more bullshit when I visit the shop.
Little Wing likes this.
Gary R is offline
post #5 of 19 (permalink) Old 10-25-2014, 09:23 PM
There is some truth to that.
On a TTS master tune you can see it
Even Docs tuning in FL can tell you that.
I have seen it as well it throws bs dtc codes acts like its pinging but its not.
On a Tmax you wont see that it does not use it.
Here's the funny thing SE wires are cheaper then Stock spark plug wires.
Why is that?
DragoBikeWorks is offline
post #6 of 19 (permalink) Old 10-25-2014, 09:38 PM Thread Starter
Gary R's Avatar
Why is that?
Yep he's a TTS guy so that explains it. I was having a hard time thinking this dude was full of crap.
So is there nothing in red better or at least as good than the stock black wires? I can wrap the stocks, I guess but if it's only about looks I don't really care.
Gary R is offline
post #7 of 19 (permalink) Old 10-27-2014, 04:07 PM
124shark's Avatar
If you do some searching you will find a TSB direct from HD that use of the SE wires does in fact create issueson EFI bikes. ION sensor is one code that is common. Stock wires are more than up to the task.
2012 FLTRX 124 S&S
124shark is offline
post #8 of 19 (permalink) Old 10-28-2014, 06:56 AM
We use the OE wires here.
No power increase in a different wire.
Scott
Hillsidecycle.com is offline
post #9 of 19 (permalink) Old 10-31-2014, 10:01 AM
Durwood's Avatar
I have used SE wires here as well, without issue, I also like the Fuelmoto wires, just purchased a set of them for my own bike.
Jamie teamed up with Moroso and developed them with ION sensing in mind. A very robust looking ignition cable for sure.
Don't forget the tune.
Durwood is offline
post #10 of 19 (permalink) Old 10-31-2014, 10:07 AM
redbaron's Avatar
Ran SE wires on both my previous bikes for years...never had an issue.
2012 Vivid Black, FM Ceramic 2-1-2 Header + 4" slash up mufflers Power Vision, PM Super Gas MERC A/C, 12" Windvest, CVO Solo Seat, XT Rokker & Hawgwire cs300 Amp, 10" Outlawz, CD Led's, Arlen Ness lowers, Ohlins S36E + progressive monotubes
redbaron is offline
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 11:17 AM
Probably A Dumb Question - SE Spark Plug Wires Touching Gas Tank? JDisMe *General Road Glide Discussions/Pictures 16 08-06-2016 02:41 PM
Accel Plug Wires? Nevadasun Engine Related 38 06-12-2013 05:40 AM
Sweet Plug Wires cleanrider Aftermarket Accessories 13 03-10-2012 01:29 PM
Splice or Dismantle Wires or Plug? MakeARunMike Controls & Handlebars 17 03-07-2012 05:02 PM
