to oil or not to oil - Road Glide Forums
post #1 of 9 (permalink) Old 10-29-2014, 04:56 PM Thread Starter
Othello7213's Avatar
Quick question do you really have to oil your air filter. Does anyone run a dry air filter?
"LETS RIDE"
Othello7213 is offline
post #2 of 9 (permalink) Old 10-29-2014, 05:08 PM
eme56's Avatar
All K&N's (Harley brand or otherwise) require oil to work properly. Some of the newer Harley Screaming Eagle filters are dry filters (not K&N) - no oil required - easy cleaning.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
post #3 of 9 (permalink) Old 10-29-2014, 05:25 PM
You can get the oil spray from an auto parts store
rlaf75 is online now
post #4 of 9 (permalink) Old 10-29-2014, 05:27 PM
Gray Beard
lundboy1's Avatar
The most common problem is too much. It only takes a light coat to do the job.
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #5 of 9 (permalink) Old 10-29-2014, 05:37 PM
charlieb's Avatar
some filters like k&n need oil to catch the very small particles or it just goes right in the intake and thru motor, which can cause damage
charlieb is offline
post #6 of 9 (permalink) Old 10-29-2014, 05:51 PM
Get the recharge kit if you have the oilable K&N. The new Ness Big Suckers come with a filter that does not not need to be oiled. I spoke to them at length about it but do not remember the specifics.
https://www.google.com/webhp?sourcei...e+kit&tbm=shop
Drew
HogPro is offline
post #7 of 9 (permalink) Old 10-29-2014, 08:12 PM
RGUrider's Avatar
I was surprised my filter is a dry filter (marked on filter - no oil). I had stage 1 done before I picked bike up (was new, showroom floor to service dept) and was told it would be K&N. Thought all K&N's were oiled. There's a very good writeup/comparison of filters on this site, K&N doesn't rate well for engine protection. That said I am planning on changing out football anyway, when I do I will do much better research before picking next air intake. Some day, 2 in college right now, no extra funds available.
RGUrider is offline
post #8 of 9 (permalink) Old 10-30-2014, 06:51 AM
Our Ful-Flo filters,(3.5" thick, and the largest to fit under a football cover) manufactured by Green Filter, Brodock, PA, are designed to run completely dry.
Scott
Hillsidecycle.com is offline
post #9 of 9 (permalink) Old 10-30-2014, 07:39 AM
Banned
check with the mnufacture.if its ment to be oiled,oil it or like said earlier,it wont catch smaller particles.if ment to be dry,you ruin the element if oiled
PF120 is offline
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 12:09 PM
Install was not that bad..Alpine and J&M not a bad team Sixnine68 Audio 10 01-31-2014 05:28 PM
Warning mobile 1 v-twin oil not jaso ma rated any more scuba1954 Tech Area 16 10-16-2012 07:01 PM
Not One, Not Two, But... Andyman *General Road Glide Discussions/Pictures 4 04-21-2012 10:01 PM
