107 question - Road Glide Forums
post #1 of 5 (permalink) Old 11-04-2014, 01:41 AM Thread Starter
pipe3214's Avatar
107 question
If i go to a 107 and ported heads with Drago's 2.5 kit and 580 cams how much difference will i have if i switch to true duals instead a my 2-1 V&H pro pipe. Will it make that much of a difference?? Thanks in advance Dan
pipe3214 is offline
post #2 of 5 (permalink) Old 11-04-2014, 07:45 AM
neverdone's Avatar
For what it's worth. I have 2-1 vh high output pro pipe. My stage 4 dyno'ed 121 hp. A friend with true duels stage 4 dyno'ed 114 hp.
neverdone is offline
post #3 of 5 (permalink) Old 11-04-2014, 09:51 AM
I replied back to your PM. On going with duals
Now with our New H Pipe you can have the best of both worlds!
Looks like duals sound like duals and performance more like a 2:1
No pinch points under trans never had them never will!
This pipe is balanced front and rear cylinder with our matching new baffle design only from Dragos.
The left and ride sound mufflers will flow almost the same 95%
Specs .. On Hpipe
Diverter tabs
Spiral cut header inside
Ceramic coated inside and out
16 gauge steel
and Heat shields !!!
Check out Youtube Vide down below.
https://www.youtube.com/watch?v=jhAJE-QoCoM
DragoBikeWorks is offline
post #4 of 5 (permalink) Old 11-05-2014, 08:27 PM Thread Starter
pipe3214's Avatar
Wow those sound awesome. I'll look at your site for cost. Is there a brake for a 107 2.5 kit and pipes? Thank you again
pipe3214 is offline
post #5 of 5 (permalink) Old 11-05-2014, 08:38 PM
Yes there is give me call Thursday we can go over all your needs and discounts
QUOTE=pipe3214;2311314]Wow those sound awesome. I'll look at your site for cost. Is there a brake for a 107 2.5 kit and pipes? Thank you again
Sent from Motorcycle.com Free App[/QUOTE]
Fuel Moto 107 kit RoadGlide0611 Fuel Moto 90 04-14-2014 04:54 PM
107 question sharknose10 Engine Related 5 12-04-2013 09:27 PM
107 question GroundPounder Engine Related 6 09-18-2012 07:16 AM
Pipes for a 107 build RoadGlide0611 Intake and Exhaust 7 12-23-2010 11:01 AM
After 107 years in Milwaukee, Harley could leave road-king General Off-Topic Discussions 16 09-24-2010 11:00 AM
