Drive Belt suggestions - Road Glide Forums
post #1 of 7 (permalink) Old 11-07-2014, 10:15 AM Thread Starter
Olskoo's Avatar
I have a 107 with 115 hp and 123 tq . Just broke the second belt in 3500 miles (HD) belts, has anyone used the Falcon belt??
Olskoo is offline
post #2 of 7 (permalink) Old 11-07-2014, 10:44 AM
chilidogtampa's Avatar
I wonder what company makes the belts they use on the Boss Hoss, that might be the one to use right there....
googling I found this thread. looks like Gates makes em for Boss Hoss.
http://www.hdforums.com/forum/tourin...ive-belts.html
chilidogtampa is offline
post #3 of 7 (permalink) Old 11-07-2014, 11:37 AM
03 Landshrk's Avatar
Belts
I had the same problem with my 2003 within 2700 miles and went to a zipper direct fit sprokets and o ring chain set up. So far so good.
03 Landshrk is offline
post #4 of 7 (permalink) Old 11-07-2014, 04:53 PM
sj01fltri's Avatar
I will check with a riding buddy he has a T man 124 that makes 134 hp and 140 tq he just broke his first belt at 11000 miles will find out what he replaced it with.
sj01fltri is offline
post #5 of 7 (permalink) Old 11-07-2014, 05:40 PM
tdkkart's Avatar
Especially when you start putting big power through them, belt tension becomes critical to long life. Too lose is just as bad or worse than too tight. I'd bet you've been too loose, there's a lot of bikes out there with more power still running belts.
tdkkart is offline
post #6 of 7 (permalink) Old 11-07-2014, 06:25 PM Thread Starter
Olskoo's Avatar
Thanks 03 Landshrk, I ordered that chain drive conversion today. I think that should solve that problem.
Olskoo is offline
post #7 of 7 (permalink) Old 11-23-2014, 06:58 PM Thread Starter
Olskoo's Avatar
Just had my mechanic install the Zippers Performance direct fit chain and sprocket , couldn't be happier , he checked the alignment with a straight edge and the kit was dead on . Know more broken belts.
Olskoo is offline
Drive belt life mike *General Road Glide Discussions/Pictures 13 04-20-2015 09:01 PM
new tire rubbing on drive belt saccman Tech Area 7 10-24-2012 04:53 PM
Rear drive belt vetteman Tech Area 0 08-24-2012 11:30 AM
Drive belt question Boogitybob *General Road Glide Discussions/Pictures 5 05-10-2012 12:46 AM
Belt Drive Limited Compensator mrbill Troubleshooting for Road Glides 0 12-19-2010 08:00 AM
